Old 05-09-2023, 05:55 PM   #1
Hillbilly71c10
Re Windshield glass
Someone gave me two green tinted window glass for my 51 gmc 100. When I matched them to the old Glas they were just a little bit larger . Is there any wiggle room when installing them? Thanks
Hillbilly71c10 is offline   Reply With Quote
Old 05-09-2023, 06:29 PM   #2
leegreen
Re: Re Windshield glass
Well, I am not a glass guy and I did my own successfully but I would not want the job to be any harder than it was, so larger glass would worry me.
On the other hand the old glass may be small.
measure the thickness of the center of your rubber then eyeball the glass in the frame.
leegreen is offline   Reply With Quote
Old 05-09-2023, 06:31 PM   #3
Hillbilly71c10
Sorry I meant the glass is about 3/8ths larger diameter
Old 05-09-2023, 06:45 PM   #4
leegreen
Do you mean the thickness of the sheet of glass or the cut size vs the window frame? pictures run the Internet
3/8" more is a lot more in either case
Old 05-09-2023, 06:47 PM   #5
Hillbilly71c10
Yes the overall cut size
Old 05-09-2023, 07:24 PM   #6
leegreen
If you hold it in the frame does it leave any clearance for the rubber?
The rubber is basically H shaped and you could measure how thick the centre of the H is compared to the space around the window.
Old 05-09-2023, 11:48 PM   #7
mr48chev
mr48chev's Avatar
You might check with a full service glass shop about having it sanded down to match your old glass.
My ongoing truck projects:
Old 05-10-2023, 12:41 AM   #8
leegreen
there are a couple good youtube videos from one of the window seal manufacturers on how to install glass in an AD cab. Worth watching and they will give you some idea of the fit.
3/8 difference seems like a lot, I wonder if there used to be different styles of aftermarket seals available.
