Old 03-15-2023, 12:26 AM   #2326
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Got the front end back on, need to align the hood a bit but it all fits with a bit of room to spare lol. Now once the salt is going to go away I'll order the tuner and do a test drive.
Monday we did a 7hr road trip across the border to Detroit Steel rims to pick up my friends 20x8 delray rims he is putting on a 1987 Chev van, we stopped at our tire shop and got 2 mounted up with a low white wall. Can't wait to see these on the van.
While we where there we talked with the owner Adam and right hand man Steve for about an hour. What a nice bunch of guys who are very passionate about what the build. Gave them some positive feed back on my Ambassador style rims I have had on my truck for 4 years.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-29-2023, 07:12 AM   #2327
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well after needing new door seals for 2 years (they where falling off) and not liking the ones I put on in the first place, the new seals are installed and doors are back on. So far I like them they close much easier don't have to slam. The foam is softer than the others, they are from "Soff seal". I recommend!
1951 MG TD
Old 03-29-2023, 11:49 AM   #2328
OutlawDrifter
Re: My 52 GMC Build
No weatherstrip adheasive to mess with either?!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 03-29-2023, 06:20 PM   #2329
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
It looks good with front coming back together!
Advanced Design is offline   Reply With Quote
Old 04-05-2023, 12:03 AM   #2330
lower50's
lower50's's Avatar
Re: My 52 GMC Build
OH the seals are so nice to work with, I used the same seals on the black '52 I built worked great for the summer we had that truck.
I ordered my programmer/ tuner today should be here in a week or two just about right for a test drive.
1951 MG TD
Old 04-08-2023, 07:12 PM   #2331
piratexpress1369a
piratexpress1369a's Avatar
Re: My 52 GMC Build
Today would have been a great day for you to take it out Bob
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 04-11-2023, 03:08 PM   #2332
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Ya I know, I wish. I'm waiting on the programmer to come in to make it run properly with the modifications I made to the motor. But I will take it around the block Friday to check out the other parts.
1951 MG TD
Old 05-02-2023, 07:39 PM   #2333
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well quick update: I got the tuner installed and got the speedometer calibrated I have about 50mi on the new setup now. I have been driving around on the lowest power setting I have, I have yet to floor it and the amount of power scares me.
Still playing with some suspension adjustments and braking in the transmission before I see what it can do.
1951 MG TD
Old 05-03-2023, 09:04 AM   #2334
OutlawDrifter
Re: My 52 GMC Build
Very cool!
1991 Z/28, 6.0L/T56
Old 05-06-2023, 09:09 AM   #2335
piratexpress1369a
Re: My 52 GMC Build
Sounds like you need to put on a dino
63
Old 05-08-2023, 09:35 AM   #2336
6DoF
6DoF's Avatar
Re: My 52 GMC Build
send it!
6DoF is offline   Reply With Quote
Old 05-10-2023, 07:56 AM   #2337
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Very cool!
Yes I will get it on the dyno probably end of July also to the drag strip
Originally Posted by 6DoF View Post
send it!
Maybe
1951 MG TD
Old 05-10-2023, 09:25 AM   #2338
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Ok so I was fighting an oil leak at the front of the motor, and getting pissed because I though it was the front main seal that I did replace it. Bad enough it was getting on my brake rotor and wheel. Turns out it was the 2 seals I did not change because I could not get the plugs out. It is for the high pressure oil rails in the heads which control the injectors, 3500psi. The plugs where rusted in and not leaking at the time of rebuild. A couple of heat cycles and higher than stock pressure and yup.
So to get them out I had to take the front accessories off and die grind around the plugs then get my impact to get them out, the drivers side did not move with my snap on 1/2" had to brake out the big Makita 3/4", and they only get torqued to 60ftlb. As you can see the seal does not look very good.
Drove it to work today, all seems good.
1951 MG TD
Old 05-10-2023, 09:51 AM   #2339
rnrdthefox
Re: My 52 GMC Build
Wow. Very interesting project. Not a lot of room left under the hood!
rnrdthefox is offline   Reply With Quote
Old 05-10-2023, 10:35 AM   #2340
youngrodder
youngrodder's Avatar
Re: My 52 GMC Build
Leaks are the worst. At least you located the source and are on your way to sealing it up...It is always something.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-10-2023, 01:11 PM   #2341
6DoF
6DoF's Avatar
Re: My 52 GMC Build
never fails!
Old 05-11-2023, 07:13 AM   #2342
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks ya it's tight but still room to work on it. It's a fun truck.
Marc
No kidding, No leaks when I got home!
never fails!
Of course, wasn't to bad to fix.
1951 MG TD
Old 05-23-2023, 08:28 PM   #2343
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well maiden voyage with the new motor pulling our new camper, went great. I put 156mi on the truck driving it around before I took my new 5000lb camper we built 220mi round trip for the weekend. I need to get a bit of transmission tuning changes, just to get it to rev out a bit more under normal acceleration. Over all pulls very nice, and boy does it have some balls!!! Rolled into it leaving a stop sign and started to spin 2nd gear with a 1000lb tong weight. Fuel economy was only a bit more than with the old motor with the old trailer.
1951 MG TD
Old 05-24-2023, 07:47 AM   #2344
6DoF
6DoF's Avatar
Re: My 52 GMC Build
it's really hard to get better MPG while doing trailer burnouts
Old 05-24-2023, 08:44 AM   #2345
OutlawDrifter
Re: My 52 GMC Build
Glad to hear it went well. What kind of MPG are we talking?
1991 Z/28, 6.0L/T56
Old 05-24-2023, 10:33 AM   #2346
Tempest67
Tempest67's Avatar
Re: My 52 GMC Build
congrats on the first trip
amazing build, well done.........Swap Meet at Rockton this weekend?
Tempest67 is offline   Reply With Quote
Old 05-26-2023, 08:02 PM   #2347
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Yes it does not help lol But who cares.
Thanks 14L/100km or 16mpg
Thank you. No can't make that one but I will be a Unfinished Nationals June 4
1951 MG TD
Old 06-28-2023, 12:23 AM   #2348
lower50's
lower50's's Avatar
Re: My 52 GMC Build
2000km/1200mi so far, runs great and pulls like a freight train. Got a new trailer tune all set up and is perfect for my set up, holds the gear a little longer during acceleration and less fuel (almost no smoke). All the temperatures stay right where they should with or without the trailer. I'll start to play with the higher power tunes at the end of July and get it on the dyno as my friend and I are driving 9hrs to CampNdrag middle of July. In my level 3 tune (daily tune) it can spin all 4 tires shifting into 3rd at 35psi of boost and puts you in your seat.
My first official burnout, got to 3rd gear 150' long letting off.
1951 MG TD
Old 06-28-2023, 07:16 AM   #2349
OutlawDrifter
Re: My 52 GMC Build
Nice burnout! Glad it's doing what it is supposed to.
1991 Z/28, 6.0L/T56
Old 06-28-2023, 08:56 AM   #2350
youngrodder
Re: My 52 GMC Build
Very cool. I have thought about Camp N Drag but it is the weekend after GoodGuys Columbus. It's hard to do 2 back to back show weekends.
Marc
bagged, build, diesel, gmc, hot rod
