Old 04-26-2023, 11:03 PM   #26
nicklear36
nicklear36's Avatar
Re: 1970 C10 ChassisFab Build Thread
Got a remote battery jumper installed so the frame won't be stuck on the ground if (when) the battery dies.
nicklear36 is offline   Reply With Quote
Old 05-08-2023, 03:34 PM   #27
nicklear36
nicklear36's Avatar
Tear down and rebuild of the non-tilt column
Old 05-08-2023, 08:29 PM   #28
zicc1835
zicc1835's Avatar
just read your build thread nice really nice work @ light speed compared to me being stalled Im getting in the passenger seat of this build
zicc1835 is offline   Reply With Quote
Old 05-10-2023, 04:16 PM   #29
nicklear36
nicklear36's Avatar
Clean, clean, and clean some more. Gonna spray these all with ospho and then epoxy prime everything together.
This Evaporust stuff is no joke! Wish I could dunk the whole truck in it
Old 05-11-2023, 11:02 AM   #30
Stickman
Stickman's Avatar
Looking good.
Stickman is offline   Reply With Quote
Old 05-11-2023, 10:25 PM   #31
clay68c10
clay68c10's Avatar
That stuff is amazing. I didn’t believe it till I used it myself.
Nice progress
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-05-2023, 11:22 AM   #32
nicklear36
nicklear36's Avatar
Parts got a little Ospho bath. I will let this coat sit for awhile to cure. Then, I will reapply the Ospho, quickly pressure wash each part, and dry. The parts will then be ready for epoxy primer and underhood satin black.
Old 06-06-2023, 06:36 AM   #33
jjzepplin
jjzepplin's Avatar
Your doing great! This is going to be a very nice truck! Does your frame cut down area seem strong?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-06-2023, 01:13 PM   #34
nicklear36
nicklear36's Avatar
Appreciate it! The ChassisFab C notches are very very thick metal, much thicker than the original frame. I had a mobile welder come and do the frame so I'm confident in its strength.
Old 07-04-2023, 09:09 AM   #35
Basketcase889
Basketcase889's Avatar
following along! Found this while searching for chassis fab reviews posts on here!
1970 - Green LWB C10 - 250 I6/3OTT
1969 - Blue/White LWB C10 CST - 350/TH400
1950 - Original Patina 3600/S10
Basketcase889 is offline   Reply With Quote
Old 07-06-2023, 12:00 PM   #36
PowerdbyChevy79
PowerdbyChevy79's Avatar
subscribed
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 07-10-2023, 10:51 AM   #37
sakustoms
Looking good. I noticed the track bar is not adjustable. Do they set up their rear suspension so the rear diff is centered at ride height? I've done a couple air ride setups with parallel 4 link and track bar and the track bar is usually adjustable for that purpose.
sakustoms is offline   Reply With Quote
Old 07-10-2023, 11:06 AM   #38
nicklear36
nicklear36's Avatar
Hey this is a great point you bring up. I was bummed that the track bar and pinion angle is not adjustable. I set the vehicle at ride height and centered the diff before welding in. Realistically, the track bar could be cut in half and threaded to make it adjustable. The rear diff is at ~3 degrees of pinion angle, so I will have to manipulate the two-piece driveshaft angle and the motor/trans. I foresaw this when the the diff was welded in place but I got it in the ballpark I feel like.
Old 07-11-2023, 06:57 AM   #39
sakustoms
With air ride you have a little leeway when it comes to pinion angle, especially with a 2 piece D/S. When I did an 83 S10 with a 2 piece I concentrated more on making sure the angles between the trans and front driveshaft were correct since I knew that I would be playing with the ride height and my rear DS to diff angles would be changing.
Can't wait to see this project completed. My 69 has a M2 front end and coilovers all around but I'm thinking about swapping to air.
Old 08-22-2023, 12:44 PM   #40
Basketcase889
any updates?
Old 08-22-2023, 03:00 PM   #41
nicklear36
nicklear36's Avatar
Keeping me on my toes, I appreciate the motivation from this group! Here's some status updates:
1) I built some wood blocks to get the frame off the ground. The frame moves around pretty well on the Harbor Freight rollers!
2) Engine is back from the builder! It is now a 357 with aluminum intake and Brodix IK heads. I am waiting for some parts to arrive so I can smooth the block with fillable polyester primer and shoot it with orange and clearcoat. Once I finish painting it we can drop the engine/trans in the frame and then route the exhaust. I'm debating with myself whether or not to get a Gear Vendors overdrive unit to pair with the TH350. TH350 is freshly rebuilt and a great transmission so I would like to keep it.
Plus a cat tax for those interested.
Old 08-25-2023, 12:51 AM   #42
nicklear36
nicklear36's Avatar
ThermAC delete and some block work before filler primer
Old 09-18-2023, 06:42 PM   #43
nicklear36
nicklear36's Avatar
Engine painted, and got the decals installed. Just needs a clearcoat!
Old 09-18-2023, 11:00 PM   #44
MS66
MS66's Avatar
Nice build.
Are those original early style rocker covers, or reproduction?
MS66 is offline   Reply With Quote
Old 09-18-2023, 11:11 PM   #45
nicklear36
nicklear36's Avatar
Originally Posted by MS66 View Post
Nice build.
They are reproductions from Ebay. Good quality, can't complain!
Old 09-19-2023, 12:53 AM   #46
MS66
MS66's Avatar
I'm not finding that early style. Do you have a link?
Never mind, found them. $149
Old 09-19-2023, 12:57 AM   #47
nicklear36
nicklear36's Avatar
These are actually from Summit:
https://www.summitracing.com/parts/AMD-W-541
Old 09-19-2023, 10:10 AM   #48
MS66
MS66's Avatar
Thanks. Hell of a build you have going on. Gonna be nice!
Old 09-25-2023, 12:06 AM   #49
nicklear36
nicklear36's Avatar
Got the motor and trans installed this weekend. Could not find the right torque converter bolts so that was a bit frustrating. Need to do some digging for the 4701rv torque converter.
And the last snag I kind of anticipated was the drag link hitting the oil pan. It is very close, only about an inch. I think I can bend the drag link just enough make this work. Otherwise I don't know if there is any aftermarket solution for a different shaped drag link.
All in all I'm excited to start the exhaust!
Old 09-25-2023, 07:14 AM   #50
zicc1835
zicc1835's Avatar
Looking real good …. Drag see more on that ?I know I thought mine was close but it all lined up and clears the pan
