Old 05-11-2023, 09:36 AM   #1
a Good Man
a Good Man's Avatar
Speedo leak
HI ALL
I HAVE GMC JIMMY 4x4 1972 There is an Speedo leak . Is there a way to solve this problem ? Thanks
MY Facebook
( saad_alhajri ) on Instagram
a Good Man is offline   Reply With Quote
Old 05-11-2023, 11:32 AM   #2
CKfan
Re: Speedo leak
Try pulling the Driven Gear Speedometer Sleeve. There should be an O-ring on the bottom between it and the transfer case. I am in the middle of tracking one down right now for mine. Goes where the arrow points.
CKfan is offline   Reply With Quote
Old 05-11-2023, 02:54 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Speedo leak
Motor City K5 has what you guys need - It's the inner seal. Easy to press out the old one and press in the new.
Old 05-11-2023, 03:10 PM   #4
a Good Man
a Good Man's Avatar
Re: Speedo leak
Thank you guys, I would like to install it at home. Is there an installation video?
MY Facebook
Old 05-11-2023, 04:04 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Speedo leak
See if the photos here suffice, worked well enough for me: https://www.motorcityk5.com/i-13102-...=category:9415
Old 05-22-2023, 09:36 AM   #6
a Good Man
a Good Man's Avatar
Re: Speedo leak
I think that this is the most appropriate solution in my opinion instead of the complete jaw, but what is the O-ring measurement?
MY Facebook
Old 05-22-2023, 09:37 AM   #7
a Good Man
a Good Man's Avatar
Re: Speedo leak
I bought it but I'm afraid I didn't find the right screwdriver to open it because the space is too tight for the key .
MY Facebook
Old 05-22-2023, 11:52 AM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Speedo leak
Mine went in fine and immediately fixed the leak.
Just remembered this: Torqueking.com sells a new speedometer drive adapter nut that has a new sleeve installed. They are a good source for NP205 parts.
Old 05-23-2023, 01:52 PM   #9
a Good Man
a Good Man's Avatar
Re: Speedo leak
I am still at this stage haha I searched for special socket It’s a thin socket and did not find it to unlock this part.
MY Facebook
Old 05-23-2023, 03:15 PM   #10
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Speedo leak
Use a 12 point socket it will fit
Old 05-28-2023, 11:36 AM   #11
a Good Man
a Good Man's Avatar
Re: Speedo leak
Thank you sir, the job has been completed successfully
MY Facebook
Old 05-28-2023, 01:22 PM   #12
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Speedo leak
You bet - happy to hear that's fixed and thanks for the update.
Old 05-28-2023, 02:49 PM   #13
a Good Man
a Good Man's Avatar
Re: Speedo leak
I am very happy to learn from you. I was able to make a special Socket .
MY Facebook
Old 05-28-2023, 03:04 PM   #14
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Speedo leak
You WIN! That's awesome.
Old 05-28-2023, 07:16 PM   #15
CG
BlahBlahBlah
Re: Speedo leak
Wow, that's very cool you can make your own tools. Nicely done!
Old 05-29-2023, 07:55 AM   #16
a Good Man
a Good Man's Avatar
Re: Speedo leak
Thank you all . I also suspect this speedometer ratio adapter leaking as well . Would I like to exchange it for a new one . Where can I get a new one?
MY Facebook
Old 05-29-2023, 11:27 AM   #17
Tmend
Tmend's Avatar
Re: Speedo leak
4 screws and it opens. You can clean and replace the grease inside. The gaskets is most likely trash. I resealed mine using a very thing line of silicone.
Some progress is better then no progress
Tmend is online now   Reply With Quote
Old 05-29-2023, 02:58 PM   #18
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Speedo leak
I'd try this first and if unsuccessful or you need a different ratio to make the speedometer read correctly contact these folks: https://speedometercablesusa.com/gear_box_adapters.html
They assembled the one in use on my Blazer and with US parts. I'm extremely pleased with their work. Heck, get a new speedometer cable too
Old 05-29-2023, 03:52 PM   #19
a Good Man
a Good Man's Avatar
Re: Speedo leak
I don't know how to thank you guys. I'm still learning a lot from you
MY Facebook
Old 05-29-2023, 04:35 PM   #20
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Speedo leak
Here's a thread I made on the ratio adapter they made: https://67-72chevytrucks.com/vboard/...d.php?t=804681
Old 05-30-2023, 08:26 AM   #21
a Good Man
a Good Man's Avatar
Re: Speedo leak
If he leaks again, I will burn the truck hahaha
MY Facebook
Old 05-30-2023, 08:31 AM   #22
a Good Man
a Good Man's Avatar
Re: Speedo leak
I appreciate that sir , Thank you
MY Facebook
Old 06-15-2023, 06:10 AM   #23
a Good Man
a Good Man's Avatar
Re: Speedo leak
We have an old Arabic proverb that says (the last remedy for the ironing problem) I will replace everything new. Thank you all
MY Facebook
Old 06-15-2023, 07:43 AM   #24
a Good Man
a Good Man's Avatar
Re: Speedo leak
It has been installed and I hope it will not leak again.
MY Facebook
Old 06-15-2023, 07:58 AM   #25
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Speedo leak
Nice. Let us know how it works. Inshallah, no leak
