Old 05-12-2023, 07:28 AM   #1
chrismoore701
chrismoore701's Avatar
Insane oil leak
Asking for a friend who just got his engine fired up after being built 3 years ago. Older motor Fired up with synthetic oil. Did a break in. lost over 2 courts of oil in just a couple hundred miles.
He has compression
sees oil on the threads of the plugs. I am thinking valve seals, how do you check this
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 05-12-2023, 08:17 AM   #2
jjzepplin
jjzepplin's Avatar
Re: Insane oil leak
What kind of engine?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-12-2023, 09:13 AM   #3
geezer#99
geezer#99's Avatar
Re: Insane oil leak
He has compression
Pull one or both exhaust manifolds off and if it’s seals you’ll see oil crud on the valve stems right down on to the backside of the valves.
Old 05-12-2023, 09:28 AM   #4
72c20customcamper
72c20customcamper's Avatar
Re: Insane oil leak
2 quarts in a couple hundred miles . I would think it would be smoking pretty bad . Can’t see seals doing that much , my 68 327 uses oil and fouls the #1 plug regularly so I know the seals are bad but it doesn’t use that much and it hardly smokes at startup . Any plugs fouled?
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-12-2023, 09:31 AM   #5
72c20customcamper
Re: Insane oil leak
Did he break it in with synthetic oil? If so nothing broke in I would drain it put break in oil in it and redo the procedure.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-12-2023, 12:40 PM   #6
Dead Parrot
Re: Insane oil leak
Pull a couple of the oily plugs. If the tips are also oil coated, could be the valve seals. But as mentioned, a normal sign of burning oil is blue exhaust smoke.
Another reason the outside of the spark plugs could be oily is leaking valve cover gaskets. But that much leakage should show up on the floor.
OEM valve covers or aftermarket? Some aftermarket skip the baffles for the PCV connections. No baffles could cause excessive oil consumption.
Dead Parrot is online now   Reply With Quote
Old 05-12-2023, 01:58 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Insane oil leak
on tv years ago guy had similar issue with a fresh rebuild on a corvette.. turns out the intake manifold was bad and it was sucking oil down the ports it was an episode of fantomworks
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-12-2023, 02:40 PM   #8
chrismoore701
Re: Insane oil leak
thanks guys, going to try to do the break in again
Chris
Old 05-12-2023, 09:24 PM   #9
Corts60
Just here to tinker
Corts60's Avatar
Re: Insane oil leak
did he break it in with synthetic oil? If so nothing broke in i would drain it put break in oil in it and redo the procedure.
x2
