05-21-2023, 08:20 AM | #3526 |
Re: PO has me PO'd
What is the ancillary tube?
What do you think about the lokar shifter? I am considering ordering one for a different project I have. |
05-21-2023, 11:47 AM | #3527 |
Re: PO has me PO'd
Looking good not sure how I would wrap it either?? You will think of something I will need to hide some of the additional wires (new harness with more options I won’t be using at least for now AC ELEC FAN etc. )under my dash
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
05-22-2023, 07:56 AM | #3528 | |
Re: PO has me PO'd
First lokar shifter I bought was the body mount system, didn't like the idea of it flexing with body roll so I changed it to the trans mount, much better, very adaptable
05-22-2023, 08:02 AM | #3529 | ||
Re: PO has me PO'd
We'll see how things work out I thought the 55 wagon was cool, then I see the Pontiac, way cooler. Hope you don't run out of garages
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-22-2023 at 08:09 AM. |
05-22-2023, 09:12 AM | #3530 |
Re: PO has me PO'd
Sorta like this
16847610403487878513354123953573 by [url=https://www.flickr.com/photos/198023675@N07
05-24-2023, 09:48 AM | #3531 |
Re: PO has me PO'd
Need to add a little more dimension to the ring
16849359247067843717796662780623 by [url=https://www.flickr.com/photos/198023675@N07
05-24-2023, 10:44 AM | #3532 |
Re: PO has me PO'd
If it is like the coolant temperature gauges, with the probe and metal tubing to the gauge- it is a capillary tube.
It might look good coiled up under the dash, behind the gauage how you have it pictured. Are you making a new aluminum shift boot ring, or some kind of spacer? |
05-25-2023, 08:40 AM | #3533 | |
Re: PO has me PO'd
I just have to make the ring wider to cover the hole in the trans. Cover
06-03-2023, 10:02 AM | #3534 |
Re: PO has me PO'd
Started to work on the 1/2 top mounting
16858007885981027009553877446229 by [url=https://www.flickr.com/photos/198023675@N07
07-06-2023, 10:14 AM | #3535 |
Re: PO has me PO'd
16886517690527276500985582034228 by [url=https://www.flickr.com/photos/97391199@N06
Sorry for the delay, been suffering from back pain last 5 weeks Took a page from my Bridgeport clamping system and adapted to my work table I hate to cut sheetmetal on my lap Inverse of convex, equalls mind numbing, 2 different plains meet at this juncture
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-06-2023 at 10:31 AM. |
07-20-2023, 09:03 AM | #3536 |
Re: PO has me PO'd
For some reason, I couldn't replicate the first piece I made, I'll call it a senior moment,
Finally after days of thinking I put the part on my V block and was able to tap in the convex shape I needed
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-20-2023 at 09:09 AM. |
07-20-2023, 07:47 PM | #3537 |
Re: PO has me PO'd
Well my dremel finally toke a crap
Move on to the super max
07-21-2023, 08:52 AM | #3538 |
Re: PO has me PO'd
07-23-2023, 09:04 AM | #3539 |
Re: PO has me PO'd
07-23-2023, 09:56 AM | #3540 |
Re: PO has me PO'd
07-27-2023, 10:25 AM | #3541 |
Re: PO has me PO'd
16904674277572276429692810025501 by [url=https://www.flickr.com/photos/97391199@N06
Well, yesterday turned into an act of futility, just couldn't get the 1/4 round out, had I known this, I would have built it leaving it in Oh well more tap,tap
07-27-2023, 10:50 AM | #3542 |
Re: PO has me PO'd
Well that seems to be closer to what I want
16904693064114964453200015310607 by [url=https://www.flickr.com/photos/97391199@N06 Just need to cut a diagonal to form better to the inner wheel well
07-28-2023, 11:30 AM | #3543 |
Re: PO has me PO'd
Looking good, and like a lot of work, but still good.
07-29-2023, 09:02 AM | #3544 |
Re: PO has me PO'd
Thanks Bud, if one of 2 things had happened I wouldn't be in this mess.........1 had the company taken the time to form the lower flange better...........B I had 800.00 for a shipped bed side
Did you get the power train fixed? 16906356763046012728839202428304 by [url=https://www.flickr.com/photos/97391199@N06
07-29-2023, 09:16 AM | #3545 |
Re: PO has me PO'd
Speed, pressure, and lubrication are the key ingredients to drilling this rusty metal, if the metal isn't chipping, put a stone to the bit
16906362558223087563129609221321 by [url=https://www.flickr.com/photos/97391199@N06
07-30-2023, 07:21 AM | #3546 |
Re: PO has me PO'd
I got my trans pulled and stripped waiting on a rebuild kit to come in.
07-30-2023, 06:12 PM | #3547 |
Re: PO has me PO'd
Nice
one sanding disk at a time |
07-31-2023, 08:58 AM | #3548 |
Re: PO has me PO'd
16908071937102287716804100972051 by [url=https://www.flickr.com/photos/97391199@N06
09-08-2023, 10:22 AM | #3549 |
Re: PO has me PO'd
Sagaa of the rpro doors continues........
Crisis averted, channel bolts in over cut down channel Brothers sells kit for 100.00 or Precision Seal sells separate seals for 28.00 16941807728666448477401166830942 by 16941820782157924922096112536285 by [url=https://www.flickr.com/photos/97391199@N06
09-15-2023, 09:51 AM | #3550 |
Re: PO has me PO'd
New window seal came in from Precision able to buy 1 same part for both sides
Just have to cut down and install on repro door 16947856289813652441448809876343 by [url=https://www.flickr.com/photos/97391199@N06
