Old 05-23-2023, 03:10 PM   #1
pdxhall
pdxhall's Avatar
serpentine belt system
I've got this serpentine belt system on my truck. it's a 5 rib system and I thought it was from a late 70s truck. I recently discovered that is not correct while I was looking at AC compressors. The compressors for these years have a single groove belt. Can someone identify this system? here's a picture before I installed it.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 05-23-2023, 03:36 PM   #2
SCOTI
SCOTI's Avatar
Re: serpentine belt system
Those are OE GM 88-94 brackets from 4.3; 5.0; & 5.7l V8 cars/trucks/Burbs.
Those particular brackets are for a smog pump optioned vehicle.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-23-2023, 05:50 PM   #3
pdxhall
pdxhall's Avatar
Thanks Scotti, I guess they are a little newer than I thought. I actually modified mine by removing most of the smog pump mount while retaining the strength. This all came about when I started looking at AC compressors.
Sanity'66
Old 05-23-2023, 07:16 PM   #4
SCOTI
SCOTI's Avatar
Yep.... Easy enough to trim away what you don't want or leave it as is. The earlier years (88-92) had more w/o the smog mount cast in.
Earlier/pre-93 version....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
