Old 05-20-2023, 05:29 PM   #1
srfinatsunset
srfinatsunset's Avatar
Push Button Lock
1968 K10 Suburban all original.
What are you guys doing when your push button lock (rear tail gate clam shell) breaks? I have the original key and now it won’t unlock. I would use the the push button lock often so I know it worked.
I have been to 3 local Locksmiths and I get no where. They always send me somewhere else. “I don’t have the tools to take it apart.” “That’s too old for me” “we tried 250 keys. We are not authorized to open the lock”.
Looking for help.
srfinatsunset is offline   Reply With Quote
Old 05-20-2023, 09:31 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Push Button Lock
Looking for help.
Will the key still slide into it? There is a cover over the tumblers on the inside. It can come loose and pop up. If that happens the key will still slide in but the lock will not turn.
If you want to send it to me I will take a look at it and see what I can do. I have fixed quite a few of them.
I will PM you.
LockDoc
Leon
Old 05-20-2023, 10:16 PM   #3
truckster
truckster's Avatar
"We are not authorized to open the lock..."
WHAT???
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 05-21-2023, 12:55 AM   #4
srfinatsunset
I will PM you.
LockDoc
The key will slide into the lock with no problem.
Old 05-21-2023, 10:55 PM   #5
3757chevy
3757chevy's Avatar
LockDoc did a great job for me on my 68 Burb. I would recommend him any day.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 05-22-2023, 02:19 PM   #6
HO455
HO455's Avatar
Leon is the man! He overhauled mine and now it's butter smooth.
RIP Bob Parks.
Old 05-22-2023, 11:37 PM   #7
LockDoc
LockDoc's Avatar
Thanks guys. I think his lock is on the way....
LockDoc
Leon
Old 05-25-2023, 07:51 PM   #8
LockDoc
LockDoc's Avatar
Lock is fixed. Just as I thought, the cover came loose and popped up. You can see it in this picture. It is supposed to be down flush with the lock surface. I removed the cover and twisted the "tabs" on each end of the cover so it would stay in place long enough for me to re-stake it. You shouldn't have any more problems with it.... This can also happen to door and ignition lock cylinders.
LockDoc
Leon
Old 04-23-2025, 10:17 AM   #9
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
LockDoc
Sorry to hijack but I have a newly acquired 72 Suburban. It didn’t have keys with it so I drilled the ignition and ordered replacements. Neither of the door locks had a code stamped and I haven’t removed the push button to check. If I sent a key and the rear push button lock, could you key it to match my replacements? The 2 local locksmiths just looked at me like I was crazy. They both said “buy a new one”. I tried to explain that we’re not available but they insisted I could.
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
72 GMC Suburban 1500 Super Custom. White/Med Olive/White, Parchment interior.
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
78 AM General M35A2C with winch, multifuel with C turbo, bobbed deuce on 47” tires.
dutchmanz is offline   Reply With Quote
Old 04-24-2025, 12:21 AM   #10
LockDoc
LockDoc's Avatar
That would be doable as long as the replacement keys will slide into the original lock easily.
Leon
Old 04-24-2025, 12:26 AM   #11
dutchmanz
dutchmanz's Avatar
My replacements haven’t arrived yet. Once they do, I’ll see if they are compatible. If not, can you disassemble the push button and determine the code for a replacement key? I’d like to have it working even if it takes a separate key.
Old 04-24-2025, 06:56 PM   #12
LockDoc
LockDoc's Avatar
Take a look at this thread I posted back in 2013. I shows how to find the code number on the tailgate lock, if it has one.
http://67-72chevytrucks.com/vboard/s...d.php?t=561226
If it has a code number I can cut a key from that, or you may have a locksmith local to you that can cut the key from the code number.....
Let me know what you find.
Leon
Old 04-25-2025, 06:53 AM   #13
dutchmanz
dutchmanz's Avatar
This is excellent info! I was hesitant to try to remove it knowing how rare the seem to be. I have some key experience from my early days in a GM dealership. I was one of the guys that recoded many of the cylinders for replacement locks. Unfortunately all that stuff was replaced when the new digital key machines came out. All paper code manuals are gone. I would have loved to get my hands on all that stuff because I had the crimp tool for the door lock stainless bezel, the tumbler stake tool and even the tool to remove the key knock out.
Old 04-25-2025, 11:03 PM   #14
LockDoc
LockDoc's Avatar
I purchased the hand key punch and code books when a local Chevy dealer went out of business a few years ago. I have used it a lot. Let me know if you need anything.
Leon
