Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 02-25-2023, 07:57 PM   #26
C130Nav
Re: 1971 2wd to 4wd conversion build
Still have to fab patches around the tailight area
C130Nav is offline   Reply With Quote
Old 04-25-2023, 03:53 PM   #27
HO455
HO455's Avatar
Great work. I'm glad to see that things are progressing.
RIP Bob Parks.
Old 04-28-2023, 05:41 AM   #28
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice burb you saved and nice rust repair work! On the 4x4 swap, did the 2wd e brake cable mounts interfere with your shackle mount positions?
Ryan
1969 Chevy milk truck
Old 05-01-2023, 09:08 PM   #29
C130Nav
Thanks!
Haven't gotten that far yet...
Old 05-30-2023, 09:03 PM   #30
C130Nav
More rust repair work done. Driver's side rocker panel. Luckily the inner rocker didnt need anything other than a good sandblasting, and a few pinholes welded up. Front and rear of new rocker needed some massaging to fit; but overall an easy job.
Old 05-30-2023, 09:11 PM   #31
C130Nav
Front part of left quarter panel repaired. Had to weld a patch for inner quarter. I'm really amazed at how much dirt gets packed up inside these rockers and quarter panels. Not sure how it makes it's way inside, but it sure gets in there.
Old 05-31-2023, 08:12 AM   #32
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by C130Nav View Post
Front part of left quarter panel repaired. Had to welding a patch for inner quarter. I'm really amazed at how much dirt gets packed up inside these rockers and quarter panels. Not sure how it makes it's way inside, but it sure gets in there.
Rocker is looking good.
My Panel Truck is starting to rust in front of the rear wheel wells and has some dirt, mud, and other junk packed in there. I'm not sure how it gets in there either but I need to get it cleaned out.
LockDoc
Leon
Old 05-31-2023, 02:12 PM   #33
C130Nav
Decided to redo the right side front rocker panel. Making a truck rocker fit a burb took some cutting and fabbing around the B pillar area. But its done; and doesnt look all that bad. In hindsight, I think it would be easier to cut the truck rocker vertically just forward of the 'burb specific B pillar area, and weld a vertical seam down the rocker...
Old 05-31-2023, 04:31 PM   #34
LockDoc
LockDoc's Avatar
I thought they made rockers for the suburbans?
LockDooc
Leon
Old 05-31-2023, 08:36 PM   #35
C130Nav
LockDooc
They do for the 3rd door; and it fit pretty well; but dont think they make a right front rocker for the 'burb. If they do, then I messed up and ordered a truck rocker by mistake. Sure made more work for me. The driver side rocker seemed to be same as C10
Old 06-09-2023, 03:59 PM   #36
KFF 1
KFF 1's Avatar
I had the same issue with the right side rocker. Used the C-10 rocker and had to fab the Burb pieces in back at the B-pillar. Also had to use C-10 B-pillar and modified it to make the B-pillar for the Burb.
KFF 1 is offline   Reply With Quote
Old 06-10-2023, 05:43 PM   #37
C130Nav
Was lucky that the B pillar was solid; with just a little surface rust. A pass with the sandblaster cleaned it all up nicely.
Old 01-27-2024, 02:13 PM   #38
CG
BlahBlahBlah
How is this project coming along?
Old 04-23-2024, 10:02 AM   #39
CDA 455
MidlifeCrisisUnderWay
CDA 455's Avatar
Sub'd
Any updates?
DIY4X
1972 CST Blazer <---sold
CDA 455 is offline   Reply With Quote
