06-10-2023, 01:43 PM | #1 |
how to put in brake lines
I replaced my master cylinder brake lines. That was a little difficult, not too bad.
How in the world does anyone replace their left and right or even the front to read brake lines? It looks like you'd have to disassemble part of the frame or pull the engine to get them in or out.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James |
06-10-2023, 09:24 PM | #2 | |
Re: how to put in brake lines
06-13-2023, 03:41 PM | #3 | |
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James Last edited by K10-Kansas; 06-16-2023 at 07:37 AM. Reason: typo |
06-14-2023, 05:17 PM | #4 |
I redid all my lines and I went to napa and got the brake line that you can bend by hand. They come in a coil. I did all mine with only the flaring tool. Probably wont win a show but they work. Can I suggest if you are going through the trouble of doing the lines add in some stainless flex lines while you're in there.
Good luck with it...I got hung up on several times but this forum helped me to pull it off.
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
06-16-2023, 07:44 AM | #5 | |
Thanks, it's great to know those types of lines exist in case I get stuck.
06-19-2023, 03:17 AM | #6 |
There’s also complete kits on eBay or summit. The correct length but just need to be bent.
06-19-2023, 05:30 AM | #7 |
first off, I highly recommend oem steel everywhere possible for several obvious reasons. If you can work them in with a little gentle massaging, I recommend finishing the project with them
I previously wasn't a huge fan of nicopp but several of my mechanics at work have used it for line replacements where oem was unavailable and steel line would be very difficult and time consuming. in all cases it worked well with zero failures couple summers ago I had a brake line in one of my longhorns spring a leak just before a show. I would have needed three sticks of available steel tubing to span the frame so I opted to give the nicopp a try. Made it full length in one shot, no extra unions. It turned out well and was extremely easy to work with and routed safely through factory locations. get yourself a decent flaring tool kit, tubing cutter, deburing tool, and a handful of flare nuts and you're in business no tubing benders necessary, bends easily by hand. only drawback is getting it to lie straight as it comes off a roll. now I'm not advocating for nicopp aftermarket over factory steel but I wouldn't be afraid to use it if needed good luck!
I started out with nothing - and I still have most of it |
06-19-2023, 08:47 PM | #8 |
I've bought pre bent lines for a couple of projects. When the supplier ships the brake lines they bend them to fit a box of some kind. You have to carefully un-bend.
About the nicopp line. I think its great. Easy to bend and route. Flares like butter. I buy it at Oreillys and they have many different lengths. So as I'm running the lines I buy lengths that are longer than I need. Cut to length and then only need to flare one end. |
06-19-2023, 11:34 PM | #9 | |
06-19-2023, 11:57 PM | #10 |
I went with all stainless on mine, and had a hell of a time eliminating leaks at the fittings. I actually ditched it and went with Nicop, and man is that stuff easy to work with. I'm a believer now.
06-20-2023, 05:55 AM | #11 | |
06-20-2023, 06:45 PM | #12 |
I bought the Eastwood bench flairing tool . I’m going to either make or buy on of these to make the straightening easier
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
06-22-2023, 07:19 PM | #13 |
Moderator
NiCopp is more corrosion resistant than the old steel brake line and it's easier to form.
Eastwood used to sell these for around $35 They're asking $80 now. I see them on Amazon and eBay for around $38. I have the Mastercool hydraulic flaring tool. The big kit costs just over $230 so it's not for everyone but it works very very well. It's not just 45° brake line. It forms other steel, stainless, & NiCopp to fit the Jiffy Tite transmission & oil cooler sockets and forms GM fuel line ends as well as the 37° Brit brake line taper. Home Depot carries a Husky or Klein 89030 tube bender for around $35-40. I have an old set of tube bending pliers I picked up from a flea market back in the late 1970's. They look something like this. They're good for making tweaks to bends and tighter radius bends.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 06-22-2023 at 07:33 PM. |
06-22-2023, 08:38 PM | #14 |
Years ago I finally broke down and bought the Eastwood turret style flaring tool. Works great. Never a leak.
06-23-2023, 07:45 PM | #15 |
Moderator
Those work great. I've used one at a buddies shop. They have an available 37° turret. They don't do the GM fuel lines and Jiffy Tite oil cooler lines so it's a trade off.
And please let us know if and how your repairs were successful. |
