Old 06-20-2023, 09:18 PM   #1
1972BackInBlackC10
1972BackInBlackC10's Avatar
Sound deadner & Insulation?
Anyone using both sound deadner and insulation under their carpet? Would it be too thick if i used both?
I was just going to use sound deadner but im not sure if i should use insulation as well, what are your opinions?
1972BackInBlackC10 is offline   Reply With Quote
Old 06-21-2023, 07:08 AM   #2
D.B
D.B's Avatar
Re: Sound deadner & Insulation?
I use both sound deadener and insulation. I sprayed a layer of Lizardskin heat barrier and a layer of sound deadener. Then I placed a layer of Flat Line barrier over this. And finally, the carpet with its insulation. I was told my carpet wouldn't lay flat because of the thickness of all this but it looks great. Also, it cut down the amount of noise and heat that comes up from the floor area. Made a world of difference.
D.B is offline   Reply With Quote
Old 06-21-2023, 09:50 PM   #3
LS short box
I did similar to what was said above. Dyna Mat then double sided insulation. Then standard carpet.
Pic.
Old 06-22-2023, 11:28 AM   #4
Professor Pain
Professor Pain's Avatar
Curious if y’all felt it was worth the effort?
Boys need dogs, men need trucks
Professor Pain is offline   Reply With Quote
Old 06-22-2023, 12:28 PM   #5
MikeB
MikeB's Avatar
I've done a 55 Chevy car and 82 C10 over the years with Dyna-mat type (butyl) sound deadening materials, along with a layer of Bonded Logic insulation, which is foil-lined recycled blue jean fibers.
In my experience, the butyl products do a great job of deadening sound, but almost nothing to block heat from the floor. I don't care what the manufacturers and sellers claim!
To answer your question, yes the work was worth the effort. Even 1-2 square feet on the doors made them close with a solid "thud", and cabin noise when driving down the road was noticeably, if not substantially, reduced. Heat on the floor from exhaust pipes and headers, which was really bad in the 55, became almost non-existent after I added the insulation to the sound deadening material.
BTW, there is little, if anything, to gain by covering the entire door or floor with sound deadening material. It's kind of like simply touching a bell with a finger or two to dampen the ringing. No need to grab the bell with both hands. Of course, you will want full coverage with the insulation, but I've never used it on doors.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 06-22-2023, 06:48 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I bought ACC Mass Back carpet for my truck and then got Kilmat too. So the floor has the mass back carpet and Kilmat beneath. The rear panel has just Kilmat with normal carpet over top. Truck is a lot quieter now with those in it. Installer didn't say he had any issues installing the carpet. So I guess to answer your question I would say use both and you shoudnt have any issues.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-23-2023, 02:45 AM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Sounds like a plan to me, nice write up. My flooring and upholstery are next on the list.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-23-2023, 11:41 AM   #8
68 C10 Driver
I used the Lizard Skin thermal and sound deadener. My truck is still in the process of restoration, but at looking at videos on YouTube from companies that use this product in Texas actually show a before and after thermometer reading to illustrate how effective the Lizard Skin is.
68 C10 Driver is offline   Reply With Quote
Old 06-24-2023, 10:15 AM   #9
MikeB
MikeB's Avatar
Sounds like some good stuff. Similar to undercoating that was used many years ago. But it requires lots of prep and masking before applying unless the cab is bare.
Mike
Old 06-24-2023, 10:25 AM   #10
MikeB
MikeB's Avatar
Just found this. It's what I used on two vehicles. It's significantly less expensive than DynaMat Xtreme, but works just as well, if not better, because the butyl layer is thicker.
https://www.amazon.com/Noico-deadeni...MGO/ref=sr_1_6
You'll need this tool for a good installation. Also, you'll need to clean the metal surfaces as well as possible. Lacquer thinner does a good job once you've got rid of any flakey paint or loose rust.
https://www.amazon.com/Noico-Install...df_B015WJH4ZW/
Mike
