Location: 3,018 feet above the SoCal/Mojave Desert region.
Cab to bed alignment.
Picking up a '72 long bed next week. New paint, rims, tires, built 350 and some other stuff. The cab to bed gap is suprisenly perfect. But I noticed the cab or bed sits a bit off to the side. It's not noticeable unless you're looking for it. If you're looking at the truck from the front, the cab sits to the left or the bed is to the right. But I noticed it because I was checking gabs and lines when I was checking it out. I measured the wheel base, exactly 127" on both sides. Is there
side-to-side adjustments?? Thanks. |
![]() Join Date: Dec 1999
Re: Cab to bed alignment.
Other than a bit of slop in the mounting holes, there is none provided by factory. I would guess maybe about 3/16"- 1/4" could be gained sliding cab one way and bed the other.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
my 71k mile '72 is the same. The bed sits just slightly further toward the passenger side. I've noticed this with several other similar C/K's. there's no reason to believe the bed has ever been removed, so I suspect it was just the way it is. it's far from a concerning issue to me, as I'm the only one that ever notices it.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
