#101 |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Re: Project "Buffalo Blizzard Surprise" 71 SWB build
Here goes the cab...
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#102 |
After about one month, Jesse was able to fit it in and get going on the blasting.
Cab turned out pretty good. I was pleased. Doors and hood turned out good too!!!
#103 |
Both original fenders turned out nice. No rot or holes. Nice to have a truck that came from Arizona.
#104 |
Get the parts coated before work begins on the body and panels.
#105 |
Some rot was found, but not too bad.
#106 |
Time to get the bad passenger side rocker fixed.
#107 |
Bought some Slosh Tubz sheet metal for the firewall. Ended up not using the side filler panels.
#108 |
Work gets underway smoothing out the firewall...
#109 |
![]() Join Date: Mar 2011
:Nice work …. Great progress …. ….now we can’t wait 4 years for what’s next
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#110 |
Subscribed!
My 1970 C10 ChassisFab LWB to SWB Build Thread |
#111 | |
#112 |
I wanted to try to use One Piece Products rear window, but it wouldn't fit right. When compared to my stock glass I could see that it was off slightly on the driver side. In order to use it I would have to tweak the window opening slightly. I'm debating.
#113 |
Got the body work going on the firewall.
Closed off and welded the channel, all the way around.
#114 |
Time to start shaving the drip rail. The plan is weld in a 1/4" dia piece of rod around the door.
#115 |
More body work on the passenger side rocker.
#116 |
Body work on the fuel filler hole.
Before.... After...
#117 |
The only major rust on the truck was the rear window channel. Really lucked out with this original sheet metal. This will need some repair.
#118 |
Needed to make a patch panel for the rear window channel. This was how it was done.
Finished piece. Just needed to cut out the old section and weld this in. Here we go...
#119 |
Shaved the dash by removing the radio speaker hole and defroster vents.
Also more work on the shaved drip rails.
#120 |
Some inside work to remove the radio and center vent. Making room for a double-din head unit.
#121 |
Work on getting the cab into primer.
#122 |
More work on the cab.
#123 |
Put front end back together.
#124 |
Drilled some holes in the firewall for my master cylinder and steering column. If you notice there's only two holes for the master and they're not studs. I drilled the stock pedal mount and installed rivet nuts in two holes for the master. This way I can use button head screws for a cleaner mount. The other holes have studs on the back of the firewall for mounting into the bracket.
#125 |
I decided to install some Trique Altman Easy Latches for my doors. I'm also going to try the Honda door seals. Hopefully, I have some nice closing doors.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
