07-01-2023, 09:28 PM | #1 |
frame rivet length
anyone know what length of rivet to use on a 1 ton frame? got a few that need fixed and I'm not interested in bolting it. I want to hot rivet them like original. Its just a bare frame and I can get to it easy. thanks.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
07-02-2023, 08:51 AM | #2 |
Re: frame rivet length
When I worked at Boeing, the general rule was to make the rivet protrude as far as the rivet diameter measures. Of course, that was aluminum, but I'm pretty sure the general rule is still applicable.
So basically, a 3/8 rivet should protrude 3/8" out the backside before your bucking bar mate applies his support.
I may be old, but I still enjoy the feeling of the earth rotating beneath my wheels... |
07-02-2023, 08:56 AM | #3 |
thats good info. thanks.
07-02-2023, 10:13 PM | #4 |
Take a couple photos of the process, and post them in this thread. I'd be interested to see how hot riveting is done on a hobbyist scale.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
07-03-2023, 06:39 PM | #5 |
I'll try to remember. may be awhile before it get it done.
planning on heating them with a torch and punching them in with an air hammer attachment.
07-07-2023, 05:35 PM | #6 |
One other thing that just occurred to me I forgot to mention: That rivet length "rule" is very much dependent on the fit of the rivet in the hole. Since the whole idea of riveting is to have them swell to fill the hole they're put in, it needs to be an accurate fit to keep the rivet tail from being too thin when you're bucking it.
07-07-2023, 05:43 PM | #7 | |
Also - the factory repair for a missing or mis hit rivet was a 3/8 grade 8 bolt. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
