Old 07-04-2023, 02:29 PM   #1
jumpsoffrock
How much did your driveshaft cost? When?
I am changing transmissions and have a two piece driveshaft. The rear piece was recently made before I bought the truck and looks "new".
I need the original untouched front shaft remade from scratch.
I have only one place in my town that makes them and they quoted me ~$550 to remake the front shaft from scratch using my measurements.
Does this sound about right?
jumpsoffrock is offline   Reply With Quote
Old 07-04-2023, 02:51 PM   #2
TxGary
TxGary's Avatar
Re: How much did your driveshaft cost? When?
When I went to a one piece drive shaft in my 71 short bed it was $330 for everything new in 11-18-2020.
I had rear drive shaft made for my 4x4 and the front shortened and rebuilt for $744 in 5-18-2022.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 07-04-2023, 03:39 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Apples to oranges, but -- I had a new rear driveshaft made for my K20 for $634. The original shaft mysteriously got bent when the body shop had the truck.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-04-2023, 06:05 PM   #4
sfont66
sfont66's Avatar
Not quite the same but purchase price and options offered for comparison.
One piece Driveshaft for SWB 72 C10 LS with T 56 Magnum 6 speed purchased last May 2022, With upgrade to 1350 yokes and joints .
Purchased from Silver Sport Transmissions. Built and drop shipped by Dynotech Driveshafts. Clawson,MI $568.00 shipped
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
sfont66 is offline   Reply With Quote
Old 07-04-2023, 08:15 PM   #5
jumpsoffrock
I really appreciate your input folks. It sounds like from scratch, it might be a fair price.
I'm gonna call a few shops in Los Angeles tomorrow and see what they can do for me, the gas would only be $100, but I'd have to take a day off.
Probably outta just have them do it here in town....
Old 07-05-2023, 12:33 PM   #6
Jason Banks
Jason Banks's Avatar
I paid $550 from actionmachineinc.com in Dec 2021 for a 1 piece shaft
Sonnax T3-3-2431HP Trans Slip Yoke × 1
$154.59
Custom Driveshaft - Aluminum, 3.5" OD, 1350 Series × 1
$395.46
Subtotal
$550.05
Jason Banks is offline   Reply With Quote
Old 07-05-2023, 12:44 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Driveline service Fresno
I was quoted $300-
57in
3in tube
1330 yoke
U joints and balance
Old 07-06-2023, 02:40 AM   #8
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I had both shafts, say 2018. They balanced them, installed a new carrier bearing and U-joints, $450ish. $550 doesn't surprise me, does that include balance?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-06-2023, 07:48 AM   #9
MARKDTN
Do you need a new driveshaft or just to shorten one? September 2020 I paid $160 to shorten an aluminum driveshaft plus 2 genuine Spicer U-joints.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-06-2023, 06:49 PM   #10
jumpsoffrock
I need a new one, I want the original shafts left alone in case I need to switch back to the old trans.
Old 07-07-2023, 02:57 AM   #11
Richard
Just received two CV drive shafts for my K10 project from Carolina driveline. About $1,500 shipped, little over two weeks. Was disappointed they did not clearance the front CV for more angle as I was told they would do. Originally ordered from High Angle Driveline because he makes some specailized CV joints, but Jess there thinks he has an indefinite time to ship. His prices are double, almost 3k. No problem with paying more for a unique product but gave up after 4 months with him. Left a review in the vendors section.
If ordering again online I would use Tom Woods, will ship within 24 hours and would guess a standard two ujoint shaft will be $300-$500.
Richard
Old 07-07-2023, 04:23 AM   #12
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I just had a two piece rebuilt, new carrier installed, front shaft shortened 1", a 400TH slip yoke with a combination u-joint installed along with both remaining u-joints installed, and the whole unit balanced for $255. Dennys Driveshafts sells their whole rear half driveshaft with a slip joint for $250 https://www.dennysdriveshaft.com/p22...sli.html#photo So yes, for this area in the Mid-West $550 is a bit high. A two piece shaft needs to be fully assembled with a new carrier bearing before balancing. Never use a billet carrier bearing without using a slip joint in the rear shaft. The factory carrier bearings are mounted in a flexible rubber bulb that allows the bearing to move as the rear axle moves up and down. A billet bearing is fixed in urethane and will not flex, this is why a slip joint is necessary in the second drive shaft.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 07-07-2023, 08:31 AM   #13
72c20customcamper
72c20customcamper's Avatar
Seems a little high for a front shaft . I haven't had one done but I did replace my 2 piece shaft on my dodge with a one piece 5 inch aluminum shaft from Action Machine in South Bend Indiana for under 800. I'm having them make up a new driveshaft for my Chevell with 1350 ujoint when I upgrade my transmission
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 07-07-2023, 09:36 AM   #14
ghackett1
68 C10 Longbed
ghackett1's Avatar
Original 2 piece driveshaft off my 68 C10 Longbed, they replaced the short front portion, installed new spicer u joints, balanced — cost $550 in Tampa Fl. Timing December 2022.
ghackett1 is offline   Reply With Quote
Old 07-07-2023, 11:49 AM   #15
AllGoNoShow
Last year I converted to a one piece for my long bed (4" steel) with 1350 spicer u-joints for $350. It was a truck supplier company ("Fleet Pride"-I think they are a national chain)....it was loads cheaper then the "hot-rod" shops who make driveshafts online.
AllGoNoShow is offline   Reply With Quote
Old 07-08-2023, 09:18 AM   #16
HO455
HO455's Avatar
One piece drive shaft for my Burban from Tom Woods Custom Drivelines was $329 in July of 2020.
RIP Bob Parks.
Old 07-08-2023, 08:10 PM   #17
jumpsoffrock
Sounds like a long one piece is much cheaper than a 2 piece.
Old 07-08-2023, 10:10 PM   #18
HO455
HO455's Avatar
I should mention that I have a Gearvendor behind a T350. So it was shorter than a regular 2 piece set up.
RIP Bob Parks.
Old 07-09-2023, 07:31 PM   #19
kev2809
low n' slo
kev2809's Avatar
just had mine done earlier in the year. stock 2 piece, rear section was shortened and a slip shaft added. about $550 with new u joints and carrier bearing
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-10-2023, 12:45 AM   #20
jumpsoffrock
They quoted me ~$675 for a complete fab of both shafts. $575 if the reuses my rear section.
I'll post what I pay as soon as I get it back.
Old 07-10-2023, 04:16 PM   #21
kev2809
low n' slo
kev2809's Avatar
sounds about right to me? i couldnt believe how expensive it was especially re using my stock driveshaft....but it sounds about going rate. i think without the slip shaft added it would be $400
-_--_--_ _________
Old 07-12-2023, 06:53 PM   #22
pappy 2
Paid $600 + This year @ Inland truck centers 1 pc drive shaft 2.5 in diameter.
pappy 2 is offline   Reply With Quote
