![]() Join Date: Jun 2023
2wd or 4wd fan shroud?
1970 Chevy C10 with a 350 V8 installed in the 6cyl rear mounting holes. Truck was like this when I bought it and I don't really want to remount the motor forward because I'd have to remount the trany and the exhaust too. So, Since my fan shroud doesn't line up right I'm thinking about buying another one. are the 4wd shrouds bigger (deeper) then the two wheel drive shrouds?
![]() Join Date: Dec 2009
Re: 2wd or 4wd fan shroud?
They look bigger on Classic Ind website
Link: https://www.classicindustries.com/pr...s/3901443.html Link: https://www.classicindustries.com/pr...5&gclsrc=3p.ds
20' Daredevil (Ret)
![]() Join Date: May 2003
This thread might help https://67-72chevytrucks.com/vboard/...d.php?t=842810
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Apr 2017
They are about an inch deeper. TWSS
![]() I did replace mine for that reason. It came with a 2WD version.
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
Wanna go really cheap?
![]() Picked up a fan shroud from some car at a salvage yard that was also too short, so I got some of that plastic garden divider stuff from the store and with some rivets or screws I extended that thing over my razor sharp flex fan. I probably should get one of those "CAUTION FAN" stickers just to make it look all original. ![]() ![]() |
![]() ![]() Join Date: Apr 2022
yes they are deeper. I have a 4WD shroud on my 68 as the motor is also in the I6 spot. Fan is where should be in relation to the shroud.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
Yea my engine is back in the I6 position too, really puts the electronic distributor right up against the firewall eh?
