Old 07-10-2023, 10:16 PM   #1
Custom 68
Custom 68's Avatar
Adding AC high pressure switch on service port
Hi all I've searched high and low with no luck. I want to add a high pressure switch on my AC. I'm charged and don't want to open things up if I don't need to. The only place I can add one is on the high side port where I hook the gages. Is there an adaptor I can use for this. It's 134 ports.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 07-11-2023, 02:01 AM   #2
howzzzit
howzzzit's Avatar
Re: Adding AC high pressure switch on service port
R134a quick coupler with 1/4 sae side port. Look up R134a adapters on Amazon. IMO eventually a leak at the quick connect o ring.
howzzzit is offline   Reply With Quote
Old 07-11-2023, 11:47 AM   #3
Custom 68
Custom 68's Avatar
Thanks for that, I hadn't looked in that direction. I had hoped for a screw in fitting/adaptor but that may not be possible with the schrader valve in place. I have ran this setup without the high pressure switch but I have also had what I am guessing is teh high pressure relief valve on my compressor "open". I didn't know there was one on there but that is all I have been able to sort out. I have a new compressor. It is strange but I was trying to avoid this again.
Thanks,
Dave
Dave
Old 07-11-2023, 01:51 PM   #4
howzzzit
howzzzit's Avatar
If your compressor tripped on the internal switch you might want to put a set of gauges on the system and re check your pressures. May be overcharged. Make sure you have good airflow over the condenser when checking it. Box fan etc.
