Junior Member
![]() Join Date: Oct 2022
Paint colour/code
Hi guys, trying to find the original paint code for my 1970 C10
SPID has option 4352AA White/Medium Green, so is this simply White and Medium Green from the 1970 Chevy colour chart? Ive seen some charts that have 2 medium greens which is even more confusing. If anyone knows of any modern day code I can give to my paint guy that would be most appreciated Thanks |
Re: Paint colour/code
Hello Belsh, well to find correct color is problematic. If color number is displayed in 3 digit code then no problem. When its 4 digit or a general code it's hard to find the exact color. Also if truck being exported, different paint codes for same color. Mine shows 4001FK "Special Paint" which is the darker blue and white, lighter blue is a repaint. A lot of color samples posted for 1970 and some cross reference also.
Junior Member
Thanks Charlie, think im just going to have to do some sort of colour match and get as close as i can
![]() Join Date: May 2002
That's a 532 white/medium green, my 72 has a 548 white/medium green code.
While the white/medium green color code may have changed between years, I think the base color code of medium green stayed the same, which was 503.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
![]() Join Date: Sep 2007
im thinking a 4 digit is 5139
1967custom |
![]() Join Date: Oct 2009
Belsh, your paint RPO code is 532, the other letters/numbers are not applicable.
532 = conventional two tone scheme of primary color Medium Green Poly (RPO code 529 for that color by itself) and secondary color of White (RPO 521 for that color by itself). 529 is a metallic 1970-only color (503, which was available all years in this era, was not a metallic paint). In 1970 "Conventional" two tone means white top, A-pillars, and window frames with everything else the primary color. |
#7 | |
Junior Member
