425hp409
![]() Join Date: Oct 2008
Tachometer calibration
I have three tachs and none of them read accurately when hooking them up to a running car with a known good tach connected to the engine. One is slightly high and the other 2 are about 20% fast. Is the small screw on the top rear of the tach a calibrations adjustment?
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
![]() ![]() Join Date: Jul 2002
Re: Tachometer calibration
The one in mine has never worked accurately since the HEI was installed. All the tricks have been tried, but it never worked accurately. Not sure why, but HEI doesn't give the right pulsing or something like that. I don't remember any of the adjustments,if there were any.
This is why I got a 4k diesel mechanical tach and had member tbone1964 recalibrate it to 5k and he also rescreened the face to a 5k as well. He did a great job. Also had to get a distributor with the tach drive as well. I have not used this yet as my truck isn't complete but I'm hoping it will be more accurate than the electronic tach.
To hear the frustration some go through with the factory tachs.
![]() I’ve not had any issues with either one of mine. For many years I had a used one from a 72 Blazer, and never had an issue with it, even when I put a Mallory Electronic Conversion kit in the Distributor, to replace the points, until one day the Diode in it “Gave up the Ghost”. I replaced it with a new factory model, and it works great. Gauging it against my Digital Multi-Meter Tach it’s within 20 RPM, so I’m not messing with something that works. ![]() I must be fortunate, because I don’t have any of the mentioned isssue. Good luck on figuring out the problem. And about your adjust me t question. Yes the screw on the back IS the adjustment screw for “Fine Tuning” the Tach. It helps to have someone helping you, because you have to be laying on your floorboard while you adjust the screw. Good Luck |
425hp409
I found a previous thread that addresses calibrating it with an adjusting screw that is at the top rear of the tach that is covered by tape.
I can add that, I have a tach that was reading low, also HEI. I assumed the board was bad and replaced it, using a new board from Cajun Tach shop. It still reads exactly the same, and has a hangup where it will freeze.
I assume the issue is with the physical mechanism needing recalibration, not the electronics. |
425hp409
I hooked up 3 tachs to a car with a digital timing light for a reference tach and 2 calibrated perfectly throughout the rpm range with the screw in the back. The 3rd would calibrate at idle, but read 2000 when it should have been 2500. I have 2 more to check tomorrow. ps: The test car had HEI and one of the tachs had previously been in my truck with point ignition. It read the same before calibration with both ignition sources. The tack reads ignition pulses, and doesn't care if it is HEI or Points.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette Last edited by 425HP409; 07-26-2023 at 10:30 AM. |
I just thought i would provide my findings i have with 2 used original 8cyl tachs. i am running a v8 with original 70's era GM HEI distributors. the tachs work fine and read pretty accurate(maybe out by 100 or so) when comparing to my multimeter. like 425HP409 has stated, it seems they operate off pulses from the distributor, so as long as my HEI does not wreck any of the original Tachometer circuitry, im happy to use them!
I do however have a 3rd original tach that seems to want to read over 500 RPM higher in all ranges, so im thinking its a problem with the tachometer or an adjustment, (the zero adjustment is good tho) |
Not a bad nut after all..
I have a factory tach (not reproduction) and HEI. I temporarily installed an aftermarket tach and adjusted the factory tach to match. Without AC, I was able to reach up behind the cluster and adjust the screw on the back of the tach; it doesn't take much to make a big adjustment.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
#10 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
