05-21-2023, 11:21 AM | #926 |
Re: What did you do to your truck today??
Got my front suspension put mostly back together yesterday. I'm going to look for a set of new shock bushings today. Also, the bolts that attach the new CV axles to the diff are too long, so I need to sort that out. Replaced the following parts:
Upper & lower control arm bushings Upper & lower ball joints Tie rod ends Pitman and Idler arms Sway bar end links Hubs CV Axles CV/hub seals Leaf spring and Shackle bushings are next on the list. |
05-22-2023, 02:21 AM | #927 |
Took my truck for a quick test drive today, and the upper control arms are shifting on the off-brand bushings I got from O'Reilly. I ordered a set of 41mm Moog bushings today to match all of the other components I installed. Will swap them out in a couple of days when they arrive.
05-23-2023, 05:06 PM | #928 | |
I like how the 4wd has beefier control arms.
Pulled the transmission out of the van, now it's pouring rain. I did find a transmission at the junkyard, the only one they had, but its condition is unknown. The fluid inside looked decent and there were no chunks in the pan. They will warranty it, but it will suck to do all that work then have to pull it back out if it's bad.
05-24-2023, 12:04 AM | #929 |
Well the Moog upper control arm bushings solved the slipping issue I had with the O'Reilly Precision bushings. The Moog bushings measure at 41.47mm in diameter, and the Precision are 41.13mm. That's a pretty big difference for a press fit. The Precision bushings practically fell out of the control arms, and the Moog bushings were quite difficult to press in.
05-26-2023, 11:20 AM | #930 |
I got this truck with 33’s and the p.o. cranked the torsion bars all the way up. It has been a stiff ride, there is interference when I’m turning while going out a driveway. I softened the ride by adjusting the torsion bars, each turn of the adjusting bolt lowered it about 1/8”. Eight turns and it lowered 1”. The ride was noticeably smoother, but there was interference when turning. I decided to shave off the end of the front bumper and the plastic piece there. While I was at it I replaced the shocks, one was bad. I also greased the ball joints. It looks like the upper A-arm may have been replaced as it is not rusty like everything else, and the upper A-arm ball joint has a grease zerk. The lower ball joint has no zerk.
'47 Panel to '88 K2500 Frame Swap Mechanical Speedometer Drive Solution 1947.2 1 ton Chevy Panel 1955.2 Chevy 6700 Bus/RV 1990 Chevy K1500 |
05-29-2023, 06:08 PM | #931 |
Started the process of replacing the bushings in the rear Leaf springs and shackles. Moog lists the same bushings foe both, but the shackle bushings do not have an outer metal case. I ordered a set of Moog shackles today with new bushings already installed.
Spent some time with a hammer and dolly working out some large dents in the lower front corner of the passenger bed side. I've been searching for a light blue door for six months now to address the dent in the door. Seems to be a rare color. |
05-31-2023, 05:09 AM | #932 |
The LuvShack Garage
Road Tested her this past weekend
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-01-2023, 08:47 PM | #933 |
Looking Good Craig!
06-02-2023, 06:08 AM | #934 |
The LuvShack Garage
Thanks buddy, she's 99% complete, just a few small things left...
06-02-2023, 11:57 AM | #935 |
Received and installed new rear leaf shackles. Front and rear suspension rebuild is now complete. Rides nice and smooth now with no squeaks or rattles.
06-04-2023, 12:42 AM | #936 |
At the body shop.
Less taco'd gate for the 90 needs a 2 tone now.
" That didnt make it any newer " " Dont antique the equipment " |
06-14-2023, 11:09 AM | #937 |
Well, last night I finished replacing the lower intake gaskets, and plenum gasket, cleaned the intake, replaced the exhaust manifold gaskets, and did an overall clean-up under the hood. I had a leak on the rear of the intake manifold. Looked to be a previous job done wrong.
1997 Chevrolet 2-door Tahoe 1980 (LWB soon to be SWB) 2wd. |
06-29-2023, 03:18 PM | #938 |
After months of searching, I finally found a light blue door. I'm going to repaint the window frame before installing it.
06-29-2023, 09:06 PM | #939 |
Moderator
Are you going to full two tone... paint the top of the gate Silver and Bronze below the body molding?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-30-2023, 09:13 AM | #940 |
I bought my '95 Suburban from Cobb county GA Sherriff's Dept. all I found in it was in between the bottom and back of the driver seat... white sugar powder from donuts! Seriously!
07-10-2023, 02:43 AM | #941 |
ordered a Holley sniper EFI kit for my 93 Suburban. Now im lookin at new heads, and a new cam to give my old burb some more balls while towing...... any suggestions are always welcome!!
07-10-2023, 09:16 PM | #942 |
07-12-2023, 05:50 AM | #943 |
The 305 in my '89 Cheyenne developed a low-end knock, so I replaced it with a 4.8L LS from an '02 Silverado
07-31-2023, 01:13 AM | #944 |
Replaced the passenger side door. The previous door had a big dent in it. The color isn't a good match, but at least the dent is gone. I will install the trim next.
08-12-2023, 01:14 AM | #945 |
Installed the trim on my replacement door
10-15-2023, 04:54 AM | #946 |
Been hearing some gurgling noises in the cooling system lately. When I pulled in the driveway at home later today coolant was spewing from the left radiator tank. Rad lasted 29 years so I cannot complain. Dorman replacement was in stock @ Oreilly's and a direct fit, $255 and lifetime warranty. AC Delco was more than twice that, had to be ordered with limited warranty. I would suspect it is the same part in my experience. Hope I am not taking it out for replacement soon.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
10-18-2023, 10:38 PM | #947 | |
Re: What did you do yo your truck today??
Made me want to drive around in town at night so everyone could see 90 GMC K1500. Stock height, but I added a sun roof and bucket seats. |
10-21-2023, 04:56 AM | #948 |
The LuvShack Garage
Recently found out that it's best NOT to be jam'n out in the shop
when changing plug wires. Important to here them "click" when you push them on your spark plugs. Drove 35 minutes to show after waiting all week for them to come in. About 1/2 way there she started running rough again, only to find out I was on 5. *Why the hood is popped in this picture someone took. I had to let her cool down so I could put 3 wires back on the plugs.
10-21-2023, 08:06 AM | #949 |
One day.....
LUV2XCLR8,
That's a great Pic!
DZL1. Bertha build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=733306 '72 C10 short bed. Bessie (traded) '93 C3500 CC Dually. Bertha (traded) ‘96 C1500 ECSB. Black Beauty '89 C1500 RCSB LS swap. Black Bean '06 Silverado CCSB Ghost (Wifes Truck) '12 GMC Terrain V6. Titanium Bling (Wife’s Daily) ‘14 Chevrolet Cruze. Raspberry (Daughters Ride) '99 Jeep Wrangler. Road Hog (Sons Ride) |
10-22-2023, 04:07 AM | #950 |
The LuvShack Garage
Thanks, been better if hood was closed...
