09-05-2023, 09:36 PM | #4176 |
Re: What did you do to your truck today.The 3rd chapter
09-10-2023, 08:14 PM | #4177 |
Not today but recently, put in all new drum brake components
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James |
09-10-2023, 09:31 PM | #4178 |
Fuel, and coolant lines finished up.
"If it ain't broken, fix it 'till it is!" |
09-11-2023, 11:55 AM | #4179 |
Wanted to get going on my list of projects, so I tucked up the front sway bar.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-11-2023, 06:56 PM | #4180 |
Those are good looking.
09-13-2023, 09:17 AM | #4181 |
Reverse lights without cutting M/T harness
09-13-2023, 03:28 PM | #4182 |
New master on the 68 Golden . Everything is now new and she stops very well . I’m guessing the master cylinder the PO installed was the problem all along, stopped ok but the rears were not working correctly. I can now lock up all 4 in a panic stop . To shiny though for the truck
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
09-14-2023, 05:41 PM | #4183 |
My Vintage Air 4 knob controller had its fan (off, lo, med, hi ) switch go loose last season...it would spin freely a quarter round before it "caught" and would click the switch. Well, just yesterday it let go completely and would just spin, not catch and actuate the 3 way switch. Pulled it and found that each knob has a set screw. The fan knob's screw was backed all the way out! Easy fix and with a little loctite, it'll probably never happen again... -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
09-14-2023, 06:28 PM | #4184 |
Truck is on jackstands, rear shocks removed, and will be doing the shock relocator kit this weekend
09-14-2023, 09:14 PM | #4185 |
Fixed the trans detent on the 68 golden steering column . I couldn’t get the shift lever to pull back and it really didn’t like to go into gear or into park . Took it all apart it’s amazing how 55 year old grease turns into concrete . Had to clean everything with PB Blaster and a wire brush . Lubed it put it back together and now it works like it should .
09-15-2023, 01:14 AM | #4186 |
Location: Herculaneum MO (20 minutes south of St. Louis
Replaced the 2 core radiator that was in the truck with a new 4 core from Summit. That plus a new thermostat & radiator cap, I should be running nice and cool now.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
09-15-2023, 03:42 AM | #4187 |
68 C10 Longbed
Today I installed the tow hooks on my 68: |
09-15-2023, 09:13 PM | #4188 |
Drove GMC 240 ish miles.. found a new barbque place in Carrollton, burned fuel at 12mpg $4.19/gal...dang.
The best sights are on US & State Routes... |
09-16-2023, 05:20 AM | #4189 |
68 C10 Longbed
Today I installed black wrinkled finish early LT1 style valve covers on the 355. |
09-16-2023, 07:03 PM | #4190 |
They look good.
09-16-2023, 08:22 PM | #4191 |
09-17-2023, 05:15 PM | #4192 |
68 C10 Longbed
09-17-2023, 05:16 PM | #4193 |
68 C10 Longbed
09-17-2023, 05:42 PM | #4194 |
Not necessarily to my truck but for my truck eventually. Buddy has a 68 frame that was bent in the front and he is taking all the useable parts off before he tosses it. I grabbed the auto transmission crossmember and the auto shifter linkage pedestal thing on the frame. Two more pieces down towards the manual to auto swap.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
09-18-2023, 01:07 PM | #4195 |
Installed my shock relocation kit yesterday. A little tough dealing with the rivets from below, but it worked out great.
09-18-2023, 02:18 PM | #4196 |
Used that same kit on my truck, but I was fortunate in the bed was off when I did it. Have put almost 2,000 miles on the truck in the last 18 months.
09-18-2023, 06:52 PM | #4197 |
70+ ( Old Skool Club )
I didn't do anything significant to the truck but drove it the long way home after work yesterday morning. Beautiful sunny Sunday morning with very minimal traffic about at 7:00AM so perfect day for a 75 mile drive out of the City and cross country to loop back another way. Truck was down for 18 months and our drivng season here is quickly coming to and end so been driving it as much as I can since back on the road in June.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
09-18-2023, 10:51 PM | #4198 |
Who Changed This?
Yeah, just drove mine to a store. Need to keep the juices swirling around, right?
09-19-2023, 02:31 PM | #4199 |
Finished the engine bay, the battery proved a challenge to buy.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-19-2023, 07:35 PM | #4200 |
Very nice work
