Old 09-06-2023, 02:29 PM   #1
Rg500gamma
Junior Member
Common bolt thread sizes used on 72 k20 longbed
I'm curious as to what the most commonly used bolt sizes used .
I will need to get the appropriate tap/chasers for the truck to clean out the bolt holes after paint. Obviously I will tape any studs
Thanks all.
Apologies if there is a thread already posted. I did a quick search and found nothing
Rg500gamma is offline   Reply With Quote
Old 09-06-2023, 04:01 PM   #2
body bolt
Re: Common bolt thread sizes used on 72 k20 longbed
3/8-16
body bolt is offline   Reply With Quote
Old 09-06-2023, 07:31 PM   #3
Rg500gamma
Junior Member
Thank you.
Old 09-06-2023, 10:27 PM   #4
mr.mud1
mr.mud1's Avatar
It does depend on what area of the truck you're working on.alot of the sheetmetal is attached with 5/16's coarse thread bolts,some 3/8's.on the engine,depending what engine,there will be 1/4, 5/16's, 3/8's, 7/16's and 1/2 inch coarse thread usually.if you buy or have a tap & die set with SAE standard taps,you'll have all those sizes you need.
mr.mud1 is offline   Reply With Quote
Old 09-06-2023, 11:26 PM   #5
RustyPile
RustyPile's Avatar
If you buy just 2 - 3 sizes, you'll invariably need another size or two after you get started.. Taps and dies, bought individually can get expensive.. Go to Lowes and get this 11 size set..
https://www.lowes.com/pd/IRWIN-24-Pi...Set/1003018222
RustyPile is offline   Reply With Quote
