C20 with Qa1 suspension
Has anyone bought the full qa1 suspension and installed on a c20? From all my research it appears front crossmembers are interchangeable between c10s and 20s but I want to make sure before dropping the money on it. I called them and they aren’t sure. I’ve also looked into RideTechs air and coil full suspension kits as well and they had the same response. I have leafs in the rear and am wanting a great driver as well as to lower it some.
1971 C20 Daily, Built 350/700R4 1971 K20 Project, LLY Duramax, 5 speed Allison, and 8 in lift on 37x13.50s K20 Build |
![]() Join Date: Feb 2010
Re: C20 with Qa1 suspension
I put a c20 crossmember on my c10. The only difference was the upper a frame bolts were bigger. I drilled my a frames for the bigger bolts all back together.
Thank you! That is nice to actually see someone that has done it not just a claim. Looks good
Tags |
crossmember swap, qa1 coilover, ridetech, suspension |
