Old 08-26-2023, 07:51 PM   #76
grumpyolddog
Re: 1967 buick special wagon
Nice work sir
grumpyolddog is offline   Reply With Quote
Old 09-04-2023, 09:07 PM   #77
gottattooz
gottattooz's Avatar
I finished patching up the pieces under the front fenders. Then I used seam sealer and then coated everything with flex seal
Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 09-04-2023, 09:12 PM   #78
gottattooz
gottattooz's Avatar
I mounted the cross bar for the transmission cooler so I could start making a cold air intake. I figured it out in cardboard and transferred it to sheet metal
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-04-2023, 09:18 PM   #79
gottattooz
gottattooz's Avatar
I folded it up and welded it into shape and then sprayed it with epoxy paint.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-05-2023, 10:02 AM   #80
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Moving forward! Nice job
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 09-07-2023, 10:50 PM   #81
gottattooz
gottattooz's Avatar
I made radiator brackets to secure the top. Used riv-nuts to make everything serviceable. Found some large washers in a drawer in the garage that happen to fit rubber glad hand seals for tractor trailer air line connectors. I painted everything black and assembled everything
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-07-2023, 11:27 PM   #82
3757chevy
3757chevy's Avatar
Thumbs up Re: 1967 buick special wagon
Josh
Very Nice.
'67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 09-07-2023, 11:30 PM   #83
gottattooz
gottattooz's Avatar
I opened the intake mouth a little more and assembled the intake system
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-08-2023, 12:45 PM   #84
Ol Blue K20
Nice work, going to be a driver soon.
Dale
Old 09-08-2023, 11:51 PM   #85
gottattooz
gottattooz's Avatar
I ordered power window regulators from nu-relics.com. They're special order for 4 doors and wagons. It's nice that the window switches on the g8 are in the center console. I'm thinking of mounting the rear window switches in the old ashtrays.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-09-2023, 12:45 AM   #86
3757chevy
3757chevy's Avatar
Josh
Very cool.
MIKE
Old 09-10-2023, 09:10 PM   #87
gottattooz
gottattooz's Avatar
I tackled the mounting of the front bumper. Took 1.5"x3" rectangular steel and welded 1/4 inch filler plates on the back to go between the crumple zone ribs. Held them in place with a small bolt on the front and mocked up the grille and bumper to figure out the mounting hole positions
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-10-2023, 09:15 PM   #88
gottattooz
gottattooz's Avatar
I traced where the mount slots were, drilled out the corner and cut the middle out with a cut off wheel. I found a length of bed frame rail that fits perfectly inside the rectangular steel. I welded some nuts to the back side, painted everything with epoxy paint and assembled the front bumper.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-16-2023, 06:39 PM   #89
gottattooz
gottattooz's Avatar
While I'm waiting on parts to come in for the front air dam, I decided to tackle installing the fuel door.
The thumb smudge on the paint is where I think center is on the fuel cap. Used a 3.5 inch hole saw and adjusted as I could see what lined up where
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-16-2023, 06:44 PM   #90
gottattooz
gottattooz's Avatar
Once I made sure the hole was big enough, I drilled some holes to weld through to secure the mounting ring. Ran around it a few times with the flap disc to make sure the door opens and closes seamlessly without rubbing or catching
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-19-2023, 10:58 PM   #91
gottattooz
gottattooz's Avatar
Figuring out the lower air dam. It's a 1970-1981 camaro bumper impact bar. I wanted a little dramatic drop in the center, so I cut the 2 inch bar down to 1 inch. I'm using a 2"x2"x1/4" section of angle iron to mount between the bumper bar and the lower radiator mounts to protect the radiator from parking bumps and any road hazards.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-19-2023, 11:04 PM   #92
gottattooz
gottattooz's Avatar
To suspend the air dam from the brackets behind the bumper, I split a 1.5"x3" tube to get the correct width and angle to secure the bumper to the angle iron support beam. I installed riv-nuts on the camaro bar to attach to the angle iron. The cardboard in the middle is how I'm thinking the scoop might look, but I'm still playing around with ideas
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-20-2023, 06:19 AM   #93
Ol Blue K20
Getting a lot done, looking good
Dale
Old 09-20-2023, 01:41 PM   #94
gottattooz
gottattooz's Avatar
I sectioned the bumper bar to move the sides further back to follow the shape of the front bumper. I welded the ends to the angle iron and welded the capture nuts on the backs of the brackets so I don't have to struggle putting my fingers and wrenches back there to secure everything. Then I took a side shot to see what the grind clearance will look like
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-23-2023, 10:26 PM   #95
gottattooz
gottattooz's Avatar
Making progress on the air dam. I started with the leftover wedges from when I cut up the bumper bar and moved it back. I made 6 more and made mounts for the fender behind the bumper. The driver's side picture is closest to being done. It's been an entire day's worth of work to figure it out, but I'm liking the way it's looking
I also welded the center plate for strength
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-24-2023, 09:07 PM   #96
gottattooz
gottattooz's Avatar
I buttoned up the passenger side. It's looking a little more mad max than I like, but maybe that's because it's still raw and in bare metal. Once I finish the driver's side, I'll take it off the car and welds everything up from the back side. Hopefully I'll be able to clean everything up with a flap disc and smooth out the corners.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-25-2023, 09:00 PM   #97
gottattooz
gottattooz's Avatar
So I went and bought paint for the wagon. The more I looked at the magnetic grey metallic that came on the pontiac, the more I felt like it was too dark for my taste. And, if I'm being honest, lighter colors hide bad bodywork better. So I looked through the color swatches at the paint store and I went with the old reliable gm gunmetal grey. It's a timeless color and I think it'll look great.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-28-2023, 12:29 AM   #98
gottattooz
gottattooz's Avatar
I ordered more parts (headlights, fog lights, suspension pieces) and dad and I were walking around the car. I was jokingly holding the 67-68 camaro air dam, sticking it under the rear bumper and goofing around when my dad noticed the angle of the end of the air dam matches the rear of the fender perfectly. So it looks like I found my filler piece for the back of the car.
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 09-28-2023, 04:07 PM   #99
Ol Blue K20
Gonna be bad @$$
Dale
Old 09-30-2023, 09:36 PM   #100
gottattooz
gottattooz's Avatar
I finished the main structure of the air dam. I took it off the car so I could weld up all the seams and brackets. Then my headlights and fog lights came in!
Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
