Old 09-09-2023, 04:47 PM   #1
kens65fb
6" rear drop coils questions I need advice
I have been running 4" drop coils on the rear of my 64 Fleetside for the last 2 years, and I always wished that it was a tad lower
I recently replaced my rear tires (245/45/18) (26.7" tall) with 255/55/18 tires which are 2.3 inches taller at (29.0" tall)
This raised the rear rake considerably, it's too high for my liking.
I already have a small c notch, and the shock relocation brackets and drop shocks installed.
It seems that I have 2 options, 6" drop coils, or air ride, any opinions?
Has anyone used 6" drop coils in the rear, any problems??
kens65fb is offline   Reply With Quote
Old 09-09-2023, 05:11 PM   #2
Angrywood
Re: 6" rear drop coils questions I need advice
if you got the money put it on bags. i did a coil drop for now until i get to spend the money for bags. i believe coils will be a smoother ride where bags would be more bouncy and rigid is my understanding. I like how they look parked laying flat on the ground
Angrywood is offline   Reply With Quote
Old 09-09-2023, 05:23 PM   #3
kens65fb
What size coils on the rear do you have?
I already have 4" drop coils , I'm looking to go lower.
I would like to hear from someone running 6" drop coils in the rear.
Old 09-09-2023, 06:36 PM   #4
Angrywood
now that i think about it...im not sure. i did a static drop without a c-notch. didnt have to. so im wondering if i did a 6 or just a 3" id have to look for the receipt. or ill try to measure the springs to get a better idea. ill get back to you to you and let you know. just swapped out an alternator and am blazing hot out here...
Old 09-09-2023, 10:48 PM   #5
AcampoDave
AcampoDave's Avatar
I tired them once with no c notch. Just like having no springs at all. Immediately returned them and got 4 inchers.
AcampoDave is offline   Reply With Quote
Old 09-11-2023, 12:45 PM   #6
62bagger
62bagger's Avatar
I have the 6" springs in the rear and 2" drop spindles and 2" springs in the front. I'm happy with the stance.
62bagger is offline   Reply With Quote
Old 09-11-2023, 02:02 PM   #7
SCOTI
SCOTI's Avatar
Air springs (bags) will ride just as good as coil springs can when used @ their recommended air pressure for a given height. Too little of air pressure might set it lower but it will be a bouncy ride. Too much pressure will ride higher & firmer. The need is to source the right size & type of bag/air spring for the specific application.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-11-2023, 02:47 PM   #8
jweb
jweb's Avatar
Why not just add lowering blocks? They are made in 1", 1.5" or 2"
https://www.performanceonline.com/60...rear-aluminum/
1951 Truck, LS1/4L60
1964 Suburban, current project
2014 Silverado daily driver
1953 Westerner "canned ham" trailer, rebuilt
1974 Prowler trailer, rebuilt
jweb is offline   Reply With Quote
Old 09-11-2023, 03:31 PM   #9
forestb
forestb's Avatar
x2
I would go with a 2 in drop block. That way you don't have to adjust your track bar or get new shocks.
forestb is offline   Reply With Quote
Old 09-11-2023, 03:47 PM   #10
SCOTI
SCOTI's Avatar
Originally Posted by forestb View Post
x2
I agree here since you have larger diameter wheels which help negate the scrubline downside w/the taller T/A drop blocks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
