Old 09-08-2023, 09:35 AM   #76
jrusher
Re: 1966 custom cab short
Went with a 2.250" flowmaster you build it dual exhaust kit and dynomax turbo mufflers. The exhaust shops want around 2 grand for dual exhaust now.
Had to swap tailhousings from a s10 t5 tranny to my camaro t5. Then to retain my the top portion of my factory 2 barrel air cleaner i found a older 4 barrel base and cut it out to fit a newer style quadrajet riser and I was back in buisness
jrusher is offline   Reply With Quote
Old 09-08-2023, 09:56 AM   #77
jrusher
Really happy with the 327 and camaro T5 . The camaro ratios are night and day better and the little mouse engine rips and revs so quick . I’m revving 2100 rpm at 75 mph and no lugging, 3:73 rear ratio and 28" tires
Old 09-09-2023, 09:51 PM   #78
cwcarpenter98
cwcarpenter98's Avatar
Nice work! The fresh 327 looks really good in there. Did you use a rattle can to paint it?
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 09-11-2023, 07:52 PM   #79
jrusher
No its a Nason single stage paint. I took my bell housing to paint shop and they got a fairly close match from the original grey paint that was on there.
Old 09-11-2023, 10:31 PM   #80
cwcarpenter98
That makes sense, thanks
Christian Carpenter
Old 09-11-2023, 10:36 PM   #81
jrusher
If you want the NAson paint code just let me know. Not sure how acurate it is but looks pretty close to me
Old 09-11-2023, 11:04 PM   #82
cwcarpenter98
This just gave me an idea to start a modern paint code thread for the 60-66 trucks. If you don't mind sharing it there, and here, please do.
Christian Carpenter
Old 09-13-2023, 10:11 PM   #83
jrusher
Great idea ! I have a few codes that ive used on the last 3 trucks that ive built
