Old 09-08-2023, 11:50 AM   #1
Rednwhitec20
Rednwhitec20's Avatar
C20 with Qa1 suspension
Has anyone bought the full qa1 suspension and installed on a c20? From all my research it appears front crossmembers are interchangeable between c10s and 20s but I want to make sure before dropping the money on it. I called them and they aren’t sure. I’ve also looked into RideTechs air and coil full suspension kits as well and they had the same response. I have leafs in the rear and am wanting a great driver as well as to lower it some.
1971 C20 Daily, Built 350/700R4
1971 K20 Project, LLY Duramax, 5 speed Allison, and 8 in lift on 37x13.50s
K20 Build
Rednwhitec20 is offline   Reply With Quote
Old 09-12-2023, 11:05 AM   #2
OL SKOOL
OL SKOOL's Avatar
Re: C20 with Qa1 suspension
I put a c20 crossmember on my c10. The only difference was the upper a frame bolts were bigger. I drilled my a frames for the bigger bolts all back together.
OL SKOOL is offline   Reply With Quote
Old 09-12-2023, 10:58 PM   #3
Rednwhitec20
Thank you! That is nice to actually see someone that has done it not just a claim. Looks good
K20 Build
crossmember swap, qa1 coilover, ridetech, suspension
