Old 09-17-2023, 11:06 AM   #1
GMC-V6
Question 60-66 to 73-87 Transfer...
I have 62 GMC dually... ideally I'd like to transfer its power train and body over to a 73+ frame.. Cab n chassis to Cab n chassis.
Parts of like to transfer:
Cab.
Front clip.
Engine.
Transmission.
Rear end.
If possible to swap over I'd be looking for a 2wd with a 60 inch cab to axle.
Mike
GMC-V6 is offline   Reply With Quote
Old 09-17-2023, 01:55 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 60-66 to 73-87 Transfer...
Cab.
Front clip.
Engine.
Transmission.
Rear end.
Mike
There's a couple threads, and a rather thorough one where it's discouraged.
One is a VIN matter, but depending your State you live in, it may not matter.
The other reason is the shape of the 73+ frames. I guess they bump up under the cab so it makes the whole truck sit higher on the frame. Probably look fine for a 4x4.
It's been said that the 73+ suburbans don't have this bump up and our trucks could potentially sit correctly, but I don't know if anyone has ever confirmed.
The most well known thread on this topic might be linked in the FAQ's.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-17-2023, 11:41 PM   #3
LostMy65
LostMy65's Avatar
Here's the thread. It was in the FAQ's
http://www.67-72chevytrucks.com/vboa...d.php?t=481023
Old 09-18-2023, 11:40 AM   #4
raidmagic
raidmagic's Avatar
Is your frame bad? Why do you want to switch them?
1965 C-10 1/2 ton shortbed part time daily driver
1980 C-10 1/2 ton shortbed project
raidmagic is offline   Reply With Quote
Old 09-18-2023, 10:45 PM   #5
cwcarpenter98
cwcarpenter98's Avatar
If your original frame isn't bad, your best course of action is to put the front suspension and rear axle from the squarebody on your 62 frame
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-20-2023, 04:49 PM   #6
karlbenz
On a square body truck frame you will end up with a 3" body lift unless you do some serious modifications
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 09-22-2023, 05:24 AM   #7
GMC-V6
I was going to do the front end swap but looking closer my 62 frame is all beat up and starting to have soft spots... So I'd being saving a dying frame.. So I was trying to find out what I'd need to get for a frame to slide under the truck.
I don't want a square body powertrain I want the 62s powertrain fan blade to rear end.
So figured if the front swaps why not the frames😂
Apparently that's not easily done shame they don't make much for dually parts.
So I need a 60 inch cab to axle cab n chassis frame I can put the GMC V6/4spd/Diff into.
Mike
Old 09-22-2023, 08:15 PM   #8
LostMy65
LostMy65's Avatar
You could try to find another 60-62 frame, a 63-66 would work but the bed mounts won't line up and the frame horns where the bumper mounts will be different. Then 67-72 with the same mods needed with the 63-66 frame.
Old 09-26-2023, 07:19 PM   #9
GMC-V6
I need a dual rear wheel cab n chassis frame that is 60" cab to axle.
Mike
