Old 09-18-2023, 06:52 PM   #1
yernkie
C10 2 inch rear drop
I’d like to drop the back of my 68 C10 long bed so it sits level. What are the pros and cons of blocks vs coils?
yernkie is offline   Reply With Quote
Old 09-18-2023, 08:41 PM   #2
67C10Step
67C10Step's Avatar
Re: C10 2 inch rear drop
Blocks will lower your scrub line so you need to be aware of if you have a flat tire the trailing arm or shock mount might drag. Might not be an issue at all, but worth checking. Springs don’t bring that issue into play.
1967 C10
1997 Ford Ranger
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 09-19-2023, 06:49 AM   #3
with 15" wheels a 2" block will allow your u-bolts to drag if a tire goes flat. 1.5" is the max you should run if staying with 15" wheels
Old 09-19-2023, 09:25 AM   #4
yernkie
It sounds like I would be better off with drop coils and shocks. Thanks for the info.
Old 09-19-2023, 11:30 AM   #5
JUst remember, you have50+ year springs on it now. 2" drop springs may not look like much since you already got the "time drop" built into you current ones.
Old 09-21-2023, 10:11 PM   #6
PowerdbyChevy79
PowerdbyChevy79's Avatar
Drop springs is the way to go.. no issues
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 09-21-2023, 10:13 PM   #7
yernkie
Thanks. Springs it is.
