01-08-2017, 06:18 PM | #1 |
upper side trim clips
I replaced the whole skin on the drivers door of my '72 and removed the stainless trim that is on the top. now I'd like to replace it but cant seem to find the clips any where. (of course I destroyed them taking them off) Knowing suburban parts are "different" will a truck part work? or something else like a 3m product?
Also I'd like to share some pics of my truck and progress but all the pics are on my phone can I post them from my phone? I'm not a computer guy! Thanks, Damon |
01-09-2017, 01:17 AM | #2 | |
The Older Generation
Re: upper side trim clips
Welcome to the board Damon. I've never had a Suburban with the upper trim so I'm not familiar with the clips. I would think another type of clip would work. We will see if any other burb guys chime in.... I know other members have posted pics from their phone but I have never done it. If you can e-Mail them to me I would post them for you. If you are OK with that I will PM you my e-Mail address. LockDoc
01-09-2017, 08:55 AM | #3 | |
Posted via Mobile Device |
01-09-2017, 11:41 AM | #4 |
Looks like your trim is in place.
I removed one of my clips from that same piece to take a picture. Unfortunately no macro mode on this camera. I haven't seen an equivalent in a parts catalog. Perhaps one of our vendors could chime in. I need a few pieces for the trim on my hatch.
01-09-2017, 12:27 PM | #5 | |
01-09-2017, 01:43 PM | #6 |
I think that clip is the same one that holds the truck upper side trim on, but not 100% certain. Check out mar-k.com, the probably have it or something that will work. OBTW, if that is an aftermarket door, test fit your door latches and strikers before you paint it. I had a problem with the stamping of where the door latch hole was. It was approximately a 1/4" too high, which created issues with the striker and latch alignment.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-09-2017, 04:48 PM | #7 |
Hart rod thanks for the info on mar-k, I'll check them out. Also thanks for the tip on the door. Its not a new door just a skin but its still not a GM part so...
BTW I spent this past weekend reading your build from the beginning WOW! Your suburban is spectacular sir. Thanks for all the info and inspiration |
01-09-2017, 04:58 PM | #8 |
The skin looks good from here. Did you just hammer and dolly the edge or use a special tool?
01-09-2017, 06:31 PM | #9 |
Thanks bigdav! Just a hammer and dolly. I have learned a ton of stuff while doing this project. Like welding, I decided that I would never do it if I didn't start so I did. Doing body work was/is intimidating. No better way to learn than to do!
01-21-2017, 10:02 PM | #10 |
I have a burb with the same belt moldings. I just ordered clips that look similar used for upper belt moldings on pickups. Once I receive them , I'll let you know if they work out.
01-28-2017, 09:09 AM | #11 |
Any news to report here?
01-31-2017, 02:53 PM | #12 |
I ordered clips for the upper molding from LMC and they are not the same. I'm still looking for the clips.
01-31-2017, 06:33 PM | #13 |
Thanks for letting me know and sorry you ordered them and they didn't work.I've been side tracked by a new project as of late and haven't had the time to look for them as I would like. I'll post a pic of my new toy soon. Hint, Its an older woman
09-22-2023, 04:57 PM | #14 |
Junior Member
Hey all, I'm resurrecting this thread (since it was inconclusive) so as not to start a new one.
I'm looking for upper molding (side trim) clips for my 72 Suburban. I'm attaching photos of what the originals looked like (please note the spring is missing in the sample chosen for the up close photos). The last photo shows the clip installed (notice the spring). These would appear to be the originals. The tape measure in the photo is in cm (1 inch equals 2.54 cm). As an aside, at the rear corner wings, it seems that some adhesive fastener might have been used originally. There don't appear to have been holes drilled from the factory in those places. Can anyone confirm this? I haven't found any reproduction upper side molding clips for sale anywhere, even after hours of research. I am guessing that some universal molding fastener (possibly bolt-type) will have to be used. I calculate that 54 are required (6 per front door, 5 per barn door, 15 for the passenger side and 17 for the driver side). For those of you that went through this, what fastener did you use, and where did you source them from? Thanks for your assistance with this! Regards, Nick Last edited by nsiti; 09-26-2023 at 09:17 AM. Reason: corrected # of fasteners and added breakdown |
09-23-2023, 08:44 PM | #15 |
My 71 GMC the corner trim is held on with clips. My passenger side was ripped off when I got it and the clips are visible.
09-23-2023, 09:10 PM | #16 | |
Junior Member
I'm going to measure the width of the trim and contact a specialty fastener store to see if they can provide some samples for me to try to see which one fits. Aside from size, it looks like the clips need to be push ins and not screw on, because of the tight space behind many of the holes. If anyone that has restored this trim has any advice, please let me know. Cheers, Nick |
09-24-2023, 01:57 PM | #17 |
Both of those clips are the same except the one is damaged. Here’s a few pics, one complete one and 3 broken ones.
09-24-2023, 02:34 PM | #18 |
Junior Member
