Old 09-26-2023, 12:53 PM   #51
nicklear36
nicklear36's Avatar
Re: 1970 C10 ChassisFab Build Thread
It hits the very front tip of the oil pan just before tightening the pitman arm nuts. I've been looking at Hotchkis center link/drag link since it doesn't have as much of an arch as the stock link. I think it would help clear the pan.
nicklear36 is offline   Reply With Quote
Old 09-26-2023, 05:23 PM   #52
zicc1835
zicc1835's Avatar
Your motor mounts are in the forward position ? Mine are in the rear position
zicc1835 is online now   Reply With Quote
Old 09-26-2023, 05:57 PM   #53
zicc1835
zicc1835's Avatar
Here’s one looking at the drag link it’s gray and my oil pan is metal color
Old 09-26-2023, 09:25 PM   #54
zicc1835
zicc1835's Avatar
I read back through your and you moved your steering up two inches ....utoh
Old 09-27-2023, 01:26 AM   #55
nicklear36
nicklear36's Avatar
Interesting, I don't know the history of why some mounts would be in the front position and some in the rear. Looking at the rear position though that might work 🤔. I'd have to get some new mounts
Old 09-28-2023, 02:55 PM   #56
68 C10 Driver
Great build going, outstanding work! I just started the frame teardown this month. I have the front apart, just need to remove everything in the rear. I am sure going through my share of PB Blaster on the frame disassembly.
68 C10 Driver is offline   Reply With Quote
Old 09-28-2023, 03:41 PM   #57
nicklear36
nicklear36's Avatar
Smile Re: 1970 C10 ChassisFab Build Thread
Thank you! I don't miss that step, I had wire wheel pieces in my shins for days
Doing it outside is a must, these frames are filthy.
Old 09-29-2023, 01:27 PM   #58
loudchevy
loudchevy's Avatar
Good progress. That 4 link rear is a very nice setup. Love that Teal color too.
I still randomly find them stuck in my garage clothes from my last wire wheel endeavor from weeks ago.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 10-13-2023, 01:58 PM   #59
nicklear36
nicklear36's Avatar
Got the vacuum lines cleaned up on the ol/ carb. Wire plugs are installed, headers, and power steering pump.
I was also able to clear the bottom of the oil pan with a new Hotchkis drag link. It is straight and doesn't have an arc like the stock link, which they say helps with bump steer too. I had to dent the bottom lip of the oil pan about an inch to clear still. But all things considered this was the least invasive method to get this raised steering to work without forking out for rack and pinion.
Still have lots to do, such as a custom electronic parking brake, fuel line, and class III towing hitch.
Old 10-13-2023, 02:40 PM   #60
zicc1835
zicc1835's Avatar
Very nice good progress
Old 11-06-2023, 06:59 PM   #61
nicklear36
nicklear36's Avatar
Towing hitch and fuel pump installed. I'll need to make some custom bumper brackets now to clear the hitch brackets. Gonna have to get creative with the stock rear brackets. I wanted to make a universal class III adjustable hitch work for this application since it is so much cheaper than the only hidden tow hitch offered for these trucks. I have a flip license plate to hide the receiver when not towing.
Getting pumped to fly out to Dinos Git Down to get some much needed inspiration!
Old 11-06-2023, 08:06 PM   #62
zicc1835
zicc1835's Avatar
I really like your detail on the 350 looks a lot like the little brother 327 in my build I also did the hidden hitch deal ....nice work
Old 11-07-2023, 01:26 AM   #63
nicklear36
nicklear36's Avatar
Twins! Looking real nice.
Thank you much!
Old 11-07-2023, 09:10 PM   #64
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Keep in mind the por 15 needs a top coat of some sort or it turns milky white from uv ...... Ask me how i know....build looks great and i curious as to why the rear shocks are so far inboard?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-07-2023, 10:21 PM   #65
nicklear36
nicklear36's Avatar
The ChassisFab rear is designed to fit a 15" wheel, which I won't be doing but that's why the shocks are tucked in and 4 link is inside the frame rails.
If I had to do the frame again I would have gotten it blasted and done a single stage or powdercoat. But budget is the goal here. I'd love to swap the whole frame out with a roadster shop frame in the future.
Old 11-07-2023, 10:44 PM   #66
FRENCHBLUE72
PROJECT 7DEUCE
Ya I used por 15 and am paying for it now....
MEMBER #6377
Project "7DEUCE"
Old 11-13-2023, 04:21 PM   #67
nicklear36
nicklear36's Avatar
Dino's Git Down pics! The show was incredible, I've never seen such high quality builds. It's estimated that 9000 trucks showed up.
I got to meet Del again after visiting his shop in 2015 in Burbank. He's a super cool dude and his new 4x4 builds are off the charts.
Old 11-13-2023, 04:23 PM   #68
nicklear36
nicklear36's Avatar
Bonus pics. The Burb was my favorite!! If anyone knows the owner please let me know!
Old 11-14-2023, 11:45 AM   #69
cornerstone
cornerstone's Avatar
Looks like the weather cooperated too! Thanks for the pictures.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-18-2023, 08:04 AM   #70
FRENCHBLUE72
PROJECT 7DEUCE
The show was amazing this year....
MEMBER #6377
Project "7DEUCE"
Old 12-03-2023, 02:32 PM   #71
nicklear36
nicklear36's Avatar
Re-did the fuel line to my liking.
Waiting on some exhaust pieces to show up so I can finish!
Old 12-18-2023, 03:06 PM   #72
nicklear36
nicklear36's Avatar
Exhaust installed! Progress is made... Can't wait to roll this frame out of the garage and get going on bodywork.
Old 12-18-2023, 09:24 PM   #73
zicc1835
zicc1835's Avatar
very nice
Old 12-19-2023, 11:33 PM   #74
Kronald_70GMC
Kronald_70GMC's Avatar
Late to the party here. Truck is looking great! Just caught up on the progress.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 12-30-2023, 11:07 AM   #75
Stickman
Stickman's Avatar
Looking good. I believe the owner of the Burb is from Vegas. I thought he had a build thread on here. Thanks for the pics.
Stickman is offline   Reply With Quote
