Old 08-16-2004, 11:25 PM   #1
69 longy
help 3/4 ton swap to a 1/2 ton
hi i need help on changing my 3/4 ton pick up to a 1/2 ton what do i need and what years can i get the parts off of plus going to drop it front end and rear some one help thanks. ps its a 69 long bed (lol)
69 longy is offline   Reply With Quote
Old 08-31-2004, 10:25 PM   #2
68jimmy
68jimmy's Avatar
I'm currently taking on that project right now with my 68 gmc lwb. I found a 70 lwb rolling frame that was bent in the front for $40! I have removed all of the rear suspension pieces including the cross-members. So far I have cleaned and painted them and just waiting for a good few days to tackle the truck. All I'm doing right now is swapping the entire rear suspension then just the front coils from the 1/2 as well. The reason I'm not using the front suspension is that the kid hit something real hard on the passenger front, and I'm not comfortable using those components... If you want to swap the rear leaf for the coil setup you can use the frame crossmembers from a 67-72 and you can use the rear trailing arms from as far back as a 64 or 65...
good luck.
68jimmy is offline   Reply With Quote
Old 09-01-2004, 01:14 AM   #3
69 longy
thanks
Old 09-01-2004, 03:46 AM   #4
Sublvr72
Sublvr72's Avatar
71-72 for the correct 5 lug disk brake suspension
http://www.cardomain.com/memberpage/328688/5
here is a link to my 3/4 to 1/2 ton swap...
Sublvr72 is offline   Reply With Quote
