Old 09-30-2023, 01:23 AM   #1
bobinbc
bobinbc's Avatar
Allow me to introduce Frank!
Well an 8 hour trip each way (including a 2 hr ferry ride X2) and I'm the proud new owner of this 60-61-62 Chevy ShortWide (I'm new to the internet world of this era of trucks, forgive me if that's not the correct term for this body style)
It's a Canadian built truck, model C1434 so always a shortbox fleetside I believe. It was said to be a 62 by the person I bought it from, but it's actually a 61 and has a 60 grill, which I may replace with a 63 grill! So I guess then it would be a 61-62-63
It had been parked for many years but I was told it was running and driving - HA yeah right! The guy had some big racing carb on it running off of a 5 gallon can in the bed, but running's not really the word! Trying to run more like, missing on more than it was hitting. He had it stuffed into a corner of his yard with a bunch of cars in the way so there was no trying to drive it either...I let him keep the big carb and decided I'd try to see what I could do with it once I got it home.
There was definitely some interesting stuff in the yard!
1957 Chevy black 1420 LBSS
1955 Chevy green 1300 SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 09-30-2023, 01:58 AM   #2
350TacoZilla
Re: Allow me to introduce Frank!
Good looking project to start with, already looking to have some sort of 5 lug conversion so make sure to check out what all is already done before ordering parts.
350TacoZilla is offline   Reply With Quote
Old 09-30-2023, 02:08 AM   #3
bobinbc
bobinbc's Avatar
Got it home last night and pushed it into the garage with some help from some friends and family. It was a little up hill and we barely made it! Looked it over quickly and boy I have some work to do No problem, we're not building a grand piano here!
Today after work I spent a couple hours on it and got it running, properly this time! Did a compression check, turns over good and all cylinders were close enough within reason. Turns out it's 3970010 350, blue block so nothing to get excited about, fine for now. Replaced the plugs, cap, rotor and put an Edelbrock 600 on it. Cleaned up the wiring slightly(lots more to do there) added some fresh gas and let'er rip! Fired right up and after a few seconds running it cleaned up and idled just fine. Set the timing and adjusted the mixture and it seems ok
Hooked up the headlights, all working and got the brake lights working too. Next time I get the chance to get out there I'll change the oil and filter, find an air cleaner and then move on to the transmission. One small job done few more to tackle to make it move under it's own power.
Also picked up a comfy bench so I can get rid of the Blazer buckets and console! A little sewing repair and a cover and it will work just fine, all in all not too shabby for the first day.
Old 09-30-2023, 02:14 AM   #4
bobinbc
bobinbc's Avatar
Thanks! Yes it looks like someone swapped a squarebody front crossmember onto it and added a 5 lug 12 bolt rearend to match. It has power front disc brakes and power steering. This was another reason I chose this truck, all things I would want to do anyway so definitely a bonus
Old 09-30-2023, 02:19 AM   #5
bobinbc
bobinbc's Avatar
Just a shot from another angle. It's been a long time since I've had an older shortbox fleetside, love how the box sides follow the contour of the cab!
Old 09-30-2023, 02:41 AM   #6
bobinbc
bobinbc's Avatar
The paint code on the truck is 5011 Omaha Orange, then it was painted reddish orange and finally the blue it is now. So 2 repaints in over 60 years. I picked up a couple of color samples while I was at Home Depot just for ideas, and mixed up a quick turquoise and a dirty white from some paint I had on hand, just fooling around.
Still lots of time to choose a color, won't be painting for quite a while yet, but I had to try out an idea or two right away!
Old 09-30-2023, 03:32 AM   #7
Braunschweiger
Looks like a good catch,
I'm excited to see what they conjure up with it.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 09-30-2023, 08:25 AM   #8
Getter-Done
Getter-Done's Avatar
Subbed for the build.
The early bird gets the worm,
85 Chevy K-20
Old 09-30-2023, 11:11 AM   #9
caseyjones
Glad you got it before he chopped, channeled and sectioned it!
caseyjones is offline   Reply With Quote
Old 09-30-2023, 11:42 AM   #10
notsolo
notsolo's Avatar
Great truck. Good progress to get it running, Your color mixes look really good.
notsolo is offline   Reply With Quote
Old 10-21-2023, 03:22 AM   #11
bobinbc
bobinbc's Avatar
Started gutting the cab, got rid of the seats and console, tank is mint inside so going to use it, tossed the carpet and stripped the dash out. Started cleaning up the cluster but that's a another topic. For now decided to get to work on the floor and body mounts ( or what was left of them!) Floor looked ok at first glance, just a couple small patches needed, but it was worse than I first thought....Right front mount was crumbling mass of cornflakes. Sorry no pic of that, just cut it out and moved on lol. Took it slow and managed to get the bulk of the rocker out of the way ( I knew going in they needed to be done)
Old 10-21-2023, 03:28 AM   #12
bobinbc
bobinbc's Avatar
Sorry about the sideways pictures, not sure how to fix that. I couldn't resist trying it on just for a preview! Still a lot more work to go before it goes on for real though!
Old 10-21-2023, 09:51 AM   #13
Getter-Done
Great fitment on that rocker.
Sometimes no matter how you hold the phone, They rotate.
I always crop my pictures ever so slighty and that helps.
Flip for ya.
85 Chevy K-20
Old 10-21-2023, 12:00 PM   #14
SkinnyG
SkinnyG's Avatar
Nice to see another BC knee-knocker here!
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-22-2023, 12:17 AM   #15
bobinbc
bobinbc's Avatar
Thanks for the rotation Getter-Done, I'll try the cropping too!
Hey SkinnyG it's not just a knee-knocker, it's a bone-shaker and a knuckle-breaker too! It's was also originally an Omaha Orange 61, who knows what it'll end up as...
Old 10-22-2023, 03:07 AM   #16
Grizz1963
Grizz1963's Avatar
Welcome Frank……
And Bob.
Amazing to see you straight in at the deep end.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 10-22-2023, 03:11 AM   #17
Braunschweiger
Good decision to build a knee knocker, welcome to the Club.
Greetings Harald
My 62 build thread
Old 10-22-2023, 08:50 AM   #18
66C10LB
Good find! As usual, more to do on body than anticipated, but will be a great project. So many have the roughly hacked up speaker holes, haha!
66C10LB is offline   Reply With Quote
Old 10-28-2023, 03:29 AM   #19
bobinbc
bobinbc's Avatar
Jumped to the back of the truck while I wait for parts to arrive for the cab floor. The tailgate had been welded shut sometime in the distant past. That won't work for me, need the tailgate to be operational. Cut the welds without too much trouble but found out why it was welded shut....sigh...I'm really not surprised, oh well easy fix.
Pulled bumper off (heavy) and had to cut all the bolts holding the box(bed?) onto the frame. Luckily all the wood is rotten so no worries about mucking it up! Bright side to everything Pulled the rear wheels and I was able to get the bed off by myself (VERY HEAVY) but just barely, between trying not to wreck it or my 60 yr old back lol SUCCESS now straight to the house for Tylenol and rest on the couch, tomorrow is another day!
Starting to get a little pile of "old truck" as the work continues, tip of the iceberg so far...
A little shot of the carnage underneath
Thanks for all the comments, I'm just trying to clean it up and make it a decent daily driver, I really don't want or intend to get into a full restoration, who has time for that??
Old 11-04-2023, 05:58 AM   #20
LT7A
Good work! You got it unning and driving really quick. Glad you are saving that one. One vote for the original color, gotta be pretty uncommon to see (not trying to mess with your plan - just throwing that out there).
Old 11-04-2023, 11:11 AM   #21
Justin71105
Looking really good, I've been through similar rust repairs on my 64.
1964 C10 Rusto-mod
5.3L - L59 Flex Fuel
BTR Truck Norris
Justin71105 is offline   Reply With Quote
Old 11-04-2023, 05:18 PM   #22
SkinnyG
SkinnyG's Avatar
I'm re-living trauma from the rust on my '61
Old 11-04-2023, 05:28 PM   #23
Braunschweiger
A mountain of work, the memories come back.
It will be great.
Greetings Harald
My 62 build thread
