Old 10-09-2023, 12:20 PM   #1
douce48
New Member
douce48's Avatar
Remove condenser if not using currently?
I'm installing a new radiator in a 72' GMC K2500.
It has factory air but the a/c will need some work before operational.
Should I remove the condenser in front of the radiator for better air flow until I get the a/c running?
I was also thinking of tack welding the 4 mounting nuts on the backside so if I want to reinstall the condenser, it would be easier since the condenser mounting nuts are sandwiched between the radiator and the radiator support.
Thoughts on both?
P.S. I'm finally able to post! It took a while
Thanks Bill
douce48 is offline   Reply With Quote
Old 10-09-2023, 12:43 PM   #2
Accelo
Accelo's Avatar
Re: Remove condenser if not using currently?
Leave it installed. It will be there when you need it, connected and clean.
Accelo is offline   Reply With Quote
Old 10-09-2023, 01:17 PM   #3
leftybass209
leftybass209's Avatar
I'm running an unused condenser on the front of a 3 row aluminum rad and it isn't a problem. Got over 106 here during the summer.
If the truck is in proper working condition, it should be able to pull air through both condenser and radiator while idle in traffic with the c9mpressor putting a load on the engine. If it has any overheating issues, the condenser would be the very last place I'd look.
leftybass209 is offline   Reply With Quote
Old 10-09-2023, 01:21 PM   #4
truckster
truckster's Avatar
Leave it. You don't want crap getting into the lines.
Just make sure the fins are clean. It won't affect airflow.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-09-2023, 01:29 PM   #5
PbFut
If the AC, particularly the compressor is dead than the condenser will need a good cleaning or better yet, replacement down the road. Tacking is a good idea for future, but it's not too hard to tip the radiator for access. All that to say leaving it as is is probably fine. It also gives you some idea of performance of the cooling system, at least with the AC turned off anyway.
PbFut is offline   Reply With Quote
Old 10-09-2023, 04:24 PM   #6
douce48
New Member
douce48's Avatar
Great insight and exactly the info I was looking for.
I'm going to leave the condenser installed, valid points.
I cleaned the fins and straightening any fins that needed it.
I removed the four condenser fasteners, cleaned, lubed and reinstalled them for ease of "possible" future removal. If needed, I can tip the radiator forward (as stated) to remove them.
Thanks again for the responses!
Old 10-10-2023, 07:51 AM   #7
MARKDTN
Agree. There is nothing I hate worse at a car show than an a/c vehicle with open hoses/ports etc.-or worse with the evaporator pipes sawn off. If you don't want a/c take it all the way off. Left open or half done just screams "I don't care" to me and the junk that is getting in there is making it so the open parts will have to be replaced to ever work again. Sorry. Rant over.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
