Old 10-17-2023, 04:25 AM   #1
bennylava
bennylava's Avatar
What was the factory tire size on 87?
I'm about to get new tires on my 87 2wd half ton silverado. But the tire shop seems a bit confused on what size would have been factory. I'm hoping someone here can tell me the size that would have come on the truck when it was new. It's just got the typical 15" rally wheels. Thank you
bennylava is offline   Reply With Quote
Old 10-17-2023, 07:26 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: What was the factory tire size on 87?
Base was P195/75R15.
You could order up to P235/75R15.
There also was an LR60-15B available within certain packages.
K
https://www.gm.com/content/dam/compa...olet-Truck.pdf
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-18-2023, 12:13 AM   #3
bennylava
bennylava's Avatar
Thank you sir
Old 10-18-2023, 09:33 AM   #4
nvrenuf
There should be a sticker on the door with the original size and recommended psi. (not the VIN sticker)
John
'91 Blazer, full top, bbc, 4spd, Doubler, 1 tons, 40's
nvrenuf is offline   Reply With Quote
Old 10-18-2023, 10:16 AM   #5
Keith Seymore
Speaking of stickers: An optional tire will also appear on the SPID if you still have the label in the glovebox.
Tire RPOs are Xxx (front), Yxx (rear) and Zxx (spare).
K
1979-1986
1986 - 2019
Old 10-19-2023, 10:36 PM   #6
bennylava
bennylava's Avatar
What are the characteristics of both these tire sizes? It would seem that the larger tire was considered to be an upgrade. Was there no advantage to the smaller tire?
Old 10-19-2023, 11:42 PM   #7
Dead Parrot
Ride height and engine speed. Smaller tire = lower stance and faster engine RPMs. Larger tire = higher stance and lower engine RPMs. Also will impact the speedometer accuracy.
Dead Parrot is offline   Reply With Quote
Old 10-20-2023, 08:19 AM   #8
Keith Seymore
No advantage to the consumer, other than keeping the initial vehicle purchase price down.
As a manufacturer you take the cheapest tire you can offer and use that as base. Any tire savings is multiplied by 5 (or by 4 for those vehicles that do not get a spare) so it adds up.
Yes - the larger tire is an upgrade and therefore additional cost to the customer and more revenue for GM. Tire prices are shown in the info packet I linked; it cost me an additional $250 to opt up to the P235 tires on my '87.
K
1979-1986
1986 - 2019
Old 10-20-2023, 09:06 AM   #9
Hammered 77
Hammered 77's Avatar
So if you opt for the larger tires what was done to correct speed and mileage?
Hammered 77 is offline   Reply With Quote
Old 10-20-2023, 10:41 AM   #10
Keith Seymore
Different transmission part numbers were released with internal gearing to accommodate tire and (more so) rear axle ratio options.
In some cases an external adapter was also used, as in the case of my '87 (it used the "Z" shaped version).
K
1979-1986
1986 - 2019
Old 10-20-2023, 11:13 AM   #11
MJN
MJN's Avatar
Different tire options also impacted the GVWR since different tires have different load ratings, this load capacity guide goes into detail on front/rear spring and different wheel/tire combos and even air pressure and how it changes GVWR.
https://67-72chevytrucks.com/vboard/...d.php?t=845046
Page 42 of this PDF shows the different tire sizes that were available
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 10-20-2023, 11:47 AM   #12
Keith Seymore
Good info.
The GVWR is established not only by how much weight the vehicle can carry, but also if you can get that weight moving and stopped. That includes rear axle ratio, too.
When I was establishing GVW (and GCW) ratings the final capping run was if you could get the load moving up the 16% grade at the Milford Proving Ground from a standing stop.
Yes - as linked in Post #2 of this thread.
K
1979-1986
1986 - 2019
Old 10-21-2023, 12:32 AM   #13
bennylava
bennylava's Avatar
According to that PDF, it looks like p225 and p235 tires were available. Or at least usable.
Old 10-23-2023, 08:52 AM   #14
Axle
Axle's Avatar
What size tires have you got on it now that the tire shop is 'confused'?
Axle is offline   Reply With Quote
Old 10-23-2023, 05:36 PM   #15
hatzie
Moderator
hatzie's Avatar
K
The parts books have tables with the drive and driven gears for the speedometer
They're based on the axle rato, transmission/transfer-case, and tire size.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-24-2023, 02:00 AM   #16
bennylava
bennylava's Avatar
IIRC you can change out that gear on the vehicle speed... thing. To adjust for tire size. Then your cable will tell the speedo the correct speed.
Also, anyone got any pics of other tire sizes on the stock 15" rally wheels? Minus all the off-roading tires. Just street tires. I wouldn't mind seeing some pics so I could choose the tires which look the best imo.
185 to 235 seems like a nice gap. Maybe 225 or 215 would look good.
Old 10-24-2023, 09:14 AM   #17
Keith Seymore
That is correct, for service.
They didn't swap gears in the assembly plant. The transmissions were all built up, sitting there ready to go.
K
1979-1986
1986 - 2019
Old 10-24-2023, 09:16 AM   #18
Keith Seymore
iirc you can change out that gear on the vehicle speed... Thing. To adjust for tire size. Then your cable will tell the speedo the correct speed.
Also, anyone got any pics of other tire sizes on the stock 15" rally wheels? Minus all the off-roading tires. Just street tires. I wouldn't mind seeing some pics so i could choose the tires which look the best imo.
p235 -
1979-1986
1986 - 2019
Old 10-24-2023, 09:17 AM   #19
Keith Seymore
Lr60-15
1979-1986
1986 - 2019
Old 10-24-2023, 10:48 AM   #20
geezer#99
geezer#99's Avatar
How wide were the rims with the p235’s, Kieth?
Old 10-24-2023, 03:36 PM   #21
Keith Seymore
15 x 8 rallys.
K
1979-1986
1986 - 2019
Old 10-27-2023, 04:22 PM   #22
rwjtexas
Junior Member
Have you purchased your tires ? I can make you a good deal on 4 or 5 Goodyear Wrangler P235/75R15 that I bought for my 1985 blazer. I bought 5 to have a new spare
I thought I wanted blackwall and after the fresh paint job I purchased a complete set of the Goodyear Wranger Duratrac to get the Outlined white letter tires.
I am not sure where you are in Texas but I am an hour out of Houston on the east side.
rwjtexas is offline   Reply With Quote
Old 11-04-2023, 08:36 AM   #23
bennylava
bennylava's Avatar
Yeah already got em. I'm sure you can sell those tires on facebook marketplace though, especially since you're near the city.
