Old 10-21-2023, 01:38 AM   #1
bennylava
bennylava's Avatar
What usually goes wrong with the cruise control?
I'd like to fix my cruise control on my 87 2wd 700r4 truck. But I've never worked on cruise before, and I'm at a loss on where to start. Anyone know how to diagnose a dead cruise?
I replaced the blinker stalk about 10 years ago, so it's not the factory button. That's about the most help I can give on this problem. Thank you
bennylava is offline   Reply With Quote
Old 10-21-2023, 04:46 PM   #2
kwmech
Re: What usually goes wrong with the cruise control?
fuse, vacuum source, cable sensor input
Old 10-21-2023, 07:25 PM   #3
hatzie
Moderator
hatzie's Avatar
1987 is likely Cruise III
Look in the manuals post for the Cruise III service training textbook. More will be in the service manuals.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
hatzie is online now   Reply With Quote
Old 10-21-2023, 10:49 PM   #4
temp190
Junior Member
try to check/adjust the switch on the brake pedal. that was my problem.
temp190 is offline   Reply With Quote
Old 10-22-2023, 02:49 AM   #5
bennylava
bennylava's Avatar
If it turns out that it's not cruise 3, then should I start looking for cruise 4? Or did they name it something else after that
Old 10-22-2023, 07:16 PM   #6
hatzie
Moderator
hatzie's Avatar
GM used an electromotor cruise control system on the T400 trucks and the boxy late 1980's through the rounded 1990's B Body Caprice and the F body cars.
I don't believe they used that system on the RV series squarebody trucks.
Cruise III was used when they phased out the CruiseMaster transducer systems starting in 1982 or 83.
Old 11-02-2023, 04:04 PM   #7
bennylava
bennylava's Avatar
Well upon inspection...
The linkage came off. So I reconnected it to the throttle. It was just laying there. Might have a problem with the cruise if the linkage ain't hooked up. Also made sure it wouldn't come off again.
Old 11-04-2023, 03:25 PM   #8
rick1956
rick1956's Avatar
Damn, how come it's never the easy stuff with me? Good deal
I may be old, but I still enjoy the feeling
of the earth rotating beneath my wheels...
rick1956 is offline   Reply With Quote
Old 11-05-2023, 10:30 AM   #9
bennylava
bennylava's Avatar
My problem is sometimes it will be something easy, but dreading having to fix a big problem, I'll put it off for 6 months. Only to find I could have fixed it in 10 minutes.
Old 11-05-2023, 10:50 AM   #10
TKCR
TKCR's Avatar
That’s what mine was also. PO must have just disconnected it, but it was there, just not hooked up.
Old 11-06-2023, 02:42 PM   #11
bennylava
bennylava's Avatar
I think they just come loose on their own. I believe this may be the second time it's happened to me. Several years ago when I was tired of working on the truck, the cruise broke along with a few other things. I used to know a good mechanic who has since retired, and he didn't charge me to fix the cruise. Just the fees for the other stuff. He probably just hooked that back up.
But I noticed it didn't have the little... retainer ring or whatever it is that keeps it attached to the throttle. So I added a stout rubber one which seems to function well. Also, the gap in the hook (on the opposite end) is very wide. It could easily slip off if the other end lets go first. I put a piece of rubber on the end of the hook, so it can't fall off again. Otherwise it may fall off the engine going down the road, and be lost.
