Old 08-17-2004, 10:56 PM   #1
MACKL
Almost done!
MACKL's Avatar
FS '87 1 Ton Front End DFW
A co-worker has a 1987 chevy 1 ton front end he would like to get out of the yard. He had the rolling chassis but used the rear end then torched the frame just behind the front cross member. He left the wheels on to help move it around.
It has frt disc, calipers, rotors, the whole works. The only front end part missing is the sway bar. (Yep, its mine). He thinks it even has the master cyl & booster. Sorry no pic's yet. The only catch is, IT HAS TO BE PICKED UP. NO DELIVERIES. You could pick it up for less than $50.00.
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 08-17-2004, 11:04 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'd like that, but I'm in a tight financial place right now. PM me if he gets desperate, and decides to scrap it or something.
I'm local and I have a trailer.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 08-18-2004, 12:06 AM   #3
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Is that 4wd... can someone say danaaaaa60
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 08-18-2004, 01:36 AM   #4
1969 GMC
1969 GMC's Avatar
Exactly what I was thinking, but I am pretty sure he meant a 2wd 1 ton front end. Unless he cut the frame behind the crossmember and kept the springs, axle, and framehorns?
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 08-18-2004, 06:46 AM   #5
MACKL
Almost done!
MACKL's Avatar
Sorry guys, 2WD.
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Old 08-18-2004, 11:05 AM   #6
Chevyguy111786
is it a dually front end? or just a normal 8 lug? if it's dually, WHEN CAN I COME GET IT!
Chevyguy111786 is offline   Reply With Quote
Old 08-18-2004, 08:23 PM   #7
MACKL
Almost done!
MACKL's Avatar
Chevyguy111786,
It is a dually. If you will PM with your phone number, I will have him call you at your convience. He works nights from 7:00pm till 4:00am, so make sure you specify the time to call...Kelly
V8-350
Auto/PS/PDB
Blazer Fuel Tank
