Old 11-11-2023, 09:21 PM   #26
jbrownmxr
Re: A/C air shut off valve
Can someone post a pick of the inside door vacuum switch configuration? Also it has a spring too?
jbrownmxr is offline   Reply With Quote
Old 11-12-2023, 01:29 AM   #27
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
It works like this. https://scontent-sjc3-1.xx.fbcdn.net...rg&oe=65560872
Short answer is that's operated by selecting INSIDE on your controller. That closes the upper cowl air door, and opens the kick panel door. INSIDE also shuts water circulation to the heater core via the water valve, for 1971-72. OUTSIDE does the opposite, or really, anytime that lever is not on INSIDE, the doors return to their default positions, and the water valve opens water flow to the core.
Pre-71 water valves are a bit different, IIRC. Somewhere around there, sorta I really can only speak for 71-72.
Ooops, I see the OP is old as dirt. To answer the above question, the kick panel door assm. looks like this from the front. Here's the one at the upper cowl too. Neither are a "switch". They're vacuum operated, really cool stuff, IMO. The images don't show the vacuum lines.
The RH kick panel door assembly for an A/C system includes a recirculated vacuum actuator, two brackets, one return spring with hooks, a link, two push-on nuts, four screws, and two hex nuts.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-14-2023, 10:16 PM   #28
jbrownmxr
Perfect! Exactly the pic I needed. Any line on spring and cap nuts.
Also, where’s the water valve and what’s its function?
