Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 11-12-2023, 05:51 PM   #1
rharris
rharris's Avatar
2001 Sonoma Brakes
The MC most likely went empty due to a blown line. I replaced the line and can not build pressure. I have clean fluid at all four corners when vacuum bleeding. I bench bled the MC and still cant get any pressure at the pedal. Any help would be appreciated. I'm suspecting ABS module has air, but I don't know how to bleed that, and im pulling fluid through it to get it out the bleeders. Stuck
72 Cheyenne Super C10 SWB
2001 Silverado 1500HD Crew
2011 Silverado 2500HD Crew Duramax (Hers)
rharris is offline   Reply With Quote
Old 11-13-2023, 08:29 AM   #2
Re: 2001 Sonoma Brakes
I'm a newbie with these trucks and anything this new. But I think you are correct that it's the ABS module hanging you up. I ran into the same problem bleeding my son's '08 Toyota Xrunner. But I don't remember how we worked that out. Hopefully someone will have your answer
Old 11-13-2023, 11:24 AM   #3
IIGW
Originally Posted by rharris View Post
I'm suspecting ABS
google will tell you that you need a tech ii or equivlent to cycle the abs module to bleed the brakes. There is really no other way to do it. Been this way for nearly 30 or so years now.
IIGW is offline   Reply With Quote
