Old 11-14-2023, 07:15 PM   #1
mvfd70
mvfd70's Avatar
Spark advance issue
Been a long time since I've been on here. Glad to see this site is still up and running. Anyways, here is my issue. 1994 Chevy K1500 with a 5.7 TBI. Using TunerPro RT this is what I see when I'm under a slight load in overdrive. The truck runs terrible and has no power to go up a small incline without downshifting to a lower gear. Sometimes even drops to 2nd gear. The spark advance appears normal until the engine starts to lug a little bit then it jumps to this 23000 number. If I mash the gas and make it shift gears so the RPMs increase the advance will drop back to a normal range.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 11-16-2023, 10:24 AM   #2
ChevyTech
Re: Spark advance issue
Has it set a code 43?
Here is an example of a hard to find code 43 I ran across.
This truck would set the code under heavy acceleration at freeway speeds.
I helped a friend of mine from an import dealer fix a code 43 a several years ago. His code started setting after installing a crate engine. After six months at two Chevrolet dealers and an import dealer, nobody wanted to work on it anymore. The circuits had been tested by several people and my thought was a mechanical knock was causing the problem. The decision was made to tear down the engine. Removing the oil pan revealed the problem. The metal baffle in the oil pan was broken loose on one side. Under certain conditions the loose baffle would rattle and the knock sensor would detect it as pinging.
Low circuit voltage on the circuit from the ESC module to the ECM for longer than 5 seconds is the other criteria (for 1989 C/K1500 350 auto) to set a code 43. When the baffle would rattle for an extended period of time, the timing would back down, the knock sensor still detected at knock the module would lower the voltage on the circuit signaling the ECM it detects a knock.
My point is, if something is loose or rattling it can cause this code, and every test in the manual won’t find the problem.
A rattle or a knock anywhere on the engine or transmission can cause the spark advance to be pulled even if it is not bad enough to get a code 43 to set.
Old 11-25-2023, 03:01 AM   #3
LT7A
This is good info. Thanks for taking the time to write it out.
Old 11-25-2023, 07:03 PM   #4
ChevyTech
Thank you for the acknowledgement.
So many posts seem to fall into the abyss.
