Help identifying my transmission...
Stock transmission, 3 on the tree... can anyone tell me if it's a Muncie or a Saginaw?
Re: Help identifying my transmission...
Base on this old thread.
https://67-72chevytrucks.com/vboard/...=216510&page=2 It's probably a Muncie. Member "Shifty" on post #31 has some of the same numbers. Post #41 shows where to find the model number. Post #56, "Shifty" finds has has a 1971 Muncie 3 speed M20. |
![]() Join Date: Mar 2003
The muncie reverse lever is in the extention housing, and the cover has 7 bolts. The Saginaw reverse shift lever is on the cover, and the cover has 7 bolts. The Borg Warner has a 9 bolt cover.
![]() Join Date: Jun 2022
https://static.summitracing.com/glob...%203733163.pdf
It's no help matching casting numbers, but by appearance, you should be able to figger it out. Hope this helps |
Check this chart.
The side cover bolt pattern will help. https://lugnutz65chevystepside.weebl...ission-id.html |
![]() Join Date: Jul 2003
Muncie:
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
Thanks to all that replied... going to crawl under the "money pit" and see what matches up.
