11-27-2023, 07:29 PM | #1 |
Painting the A/C box
Has any ever painted their A/C box like to see some pictures. Mine has a hole in it don't no if should patch it or replace that part either way I will have to be painted when done.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
11-27-2023, 07:29 PM | #2 |
Re: Painting the A/C box
11-27-2023, 07:39 PM | #3 |
While not a AC box, I painted my heater box with a flat black, might have been a can of the underhood black from like SEM I cant recall. Looks good to this day.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
11-27-2023, 07:39 PM | #4 |
I'd rough it up and lay in a patch of fiberglass on the inside. Then fill the outside with resin and smooth it out to look pretty and then paint it. You can remove that section of the box without disturbing anything other than removing the vacuum cannister
11-27-2023, 07:55 PM | #5 |
Looks good flat black and the truck is the same color as mine.
11-28-2023, 02:15 AM | #6 |
Painted mine with Krylon RT9203 semi flat black. Put a new Harrison sticker on it. Slight sheen to it. In fact I repainted everything black that was factory with the same paint when I had the engine out. Including the inner fenders when removed.
11-28-2023, 09:12 AM | #7 |
If you want to maintain factory appearance, it will be difficult to repair that so it is like it never happened. I would replace that half.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
11-28-2023, 01:16 PM | #8 |
I have one to replace it but it doesn't match so I will have to paint it.
11-29-2023, 02:00 AM | #9 |
Might get away with a similar shade of Zolatone, or one of their imitations.
11-29-2023, 02:49 AM | #10 |
For a factory look, if not damaged sand surface down to 400 or higher and apply satin clear.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
12-01-2023, 02:06 PM | #11 |
425hp409
I lightly sanded mine that had been painted black. I then dusted it with Napa Primer Grey for a near factory look. Anyway, I like it!
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
12-01-2023, 07:39 PM | #12 |
That looks nice thanks for the pictures.
