Old 12-05-2023, 08:54 AM   #1
dlbraly
dlbraly's Avatar
Mirror Screw holes
The mirrors on the 63 are loose.
The screw holes are wallered out.
Not sure if they will hold, but I ordered some of those plastic license plate nuts and screws.
At some point I will replace the mirrors, but this might keep me from spending that money until after I get it running well.
Waiting on Carburetor throttle shaft bushings to finish rebuilding it.
I plan on starting replacing the wiring harness Today.
Take Care,
Dave
dlbraly is offline   Reply With Quote
Old 12-05-2023, 11:28 AM   #2
SkinnyG
SkinnyG's Avatar
Re: Mirror Screw holes
Is the weldnut thick enough to do a heli-coil?
I used nutserts to install a passenger side mirror, perhaps you could drill it out and use a nutsert, however you'd likely have to remove all of the old weldnut as a nutsert needs relatively thin metal to attach.
A stop-gap measure can be slipping some wire in between the threads to take up some of the thread gap.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-07-2023, 04:45 PM   #3
forestb
forestb's Avatar
Can you get some longer bolts and add nuts on the other side of the wallered out nuts
forestb is offline   Reply With Quote
Old 12-07-2023, 07:09 PM   #4
dlbraly
dlbraly's Avatar
LOL, well that was a dumb idea.
I did one and it held, but can tell that will not last.
I like the nutsert idea.
Looks like they are just holes and no threads. Maybe the backing nuts fell off or something.
Yeah, I was thinking just a bolt and nut.
Take Care,
Dave
Old 12-07-2023, 07:11 PM   #5
forestb
forestb's Avatar
Is it on the drivers side or passenger side?
Old 12-07-2023, 07:48 PM   #6
dlbraly
dlbraly's Avatar
Both sides have 1 or 2 loose.
Take Care,
Dave
Old 12-14-2023, 04:33 PM   #7
Justin71105
Also used nutserts for my new doors, you can use a bolt the size of the nutsert and a size up nut to crimp them down.
They seem to be holding pretty good so far.
1964 C10 Rusto-mod
5.3L - L59 Flex Fuel
Justin71105 is offline   Reply With Quote
Old 12-14-2023, 08:55 PM   #8
karlbenz
I mounted mine with rivnuts
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
