![]() Join Date: Aug 2010
1965 Front Fender Mounting Plate "Grommets" Can't find any...
Looked around the www and talked to truck shop, can't find any...
See photo. I have one missing. Probably can get something close but just want to ask here. Sorry: can't post pic on mobile... will add it shortly. Fits inside this "plate" ![]() Thx! Roy
1965 Suburban Waiting on Time and Money Last edited by RoyL; 12-06-2023 at 07:14 PM. Reason: Add pic |
![]() Join Date: Apr 2010
Re: 1965 Front Fender Mounting Plate "Grommets" Can't find any...
1951 Truck, LS1/4L60 1964 Suburban, current project |
I never knew there was supposed to be a grommet in there. Interesting.
![]() ![]() Join Date: Apr 2012
This is a first , and I've taken apart some very low mile trucks. That grommet goes on the INNER fender bottom rear , not the bottom of a fender .
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#5 | |
Will need those, cause I don't have any grommets there either... I saw some that had a large washer and bolt that went with it, can't find it now, of course.
1965 Suburban Waiting on Time and Money |
#6 | ||
They look pretty much like the inner fender to cab grommets linked above. Maybe we are talking past each other on the location, inner vs outer. Appreciate the insight on what you've seen on other trucks!
1965 Suburban Waiting on Time and Money Last edited by RoyL; 12-08-2023 at 07:38 AM. Reason: added link |
#7 | |
Here's photo of the hole, so from the factory, there was nothing used in here? I get you need some wiggle room for fender alignment, but this is a big hole. The aftermarket one I used the picture was from Truck Shop, that hole looks smaller than mine... hmmm. Oh well, I got what I got, so I'll put something similar back in there... ![]()
1965 Suburban Waiting on Time and Money Last edited by RoyL; 12-09-2023 at 08:20 AM. Reason: Add pic |
![]() Join Date: Apr 2017
Good Morning. Here are pictures of an original paint fender and mounting plate that have not been disassembled. Hard to determine if the mounting plate has a grommet.
U.S. Army Retired and Combat Veteran Current serving DoD Civilian 1966 C20 Custom Camper Saddle 327 Automatic 1966 C20 Custom Camper Saddle 327 Automatic 1962 C1 Corvette Black/Fawn 327-300 4 spd 1966 C2 Corvette Silver/Black 327-350 4 spd |
I agree. Hard to determine. Here is the sheet from the assembly manual. It references grommet for panel or suburban.
#11 | ||
I ordered the 55-59 grommets from Truck shop, per their recommendation. Will see if it fits. Thanks again! Roy
#12 | |
Let us know how it work out. Frank
I got the grommets yesterday. They measure about 1 5/8" diameter with a 1/2" diameter hole. It's slit almost to the hole, so should be able to slide in the fender bracket hole. I'd try it on the truck, but I've temporarily mounted the fenders while I drive it a bit. Does look alot like the grommet that was on there. I'll post back when I install these.
![]() ![]() Thanks to the guy at Truck shop, I heard he had a 64 C10. Roy
#15 | |
Was wondering the same thing, the graphic you posted does show 2 different part #s. GMwiki found 3757735 and 3757736 (L&R for Cab/Cowl) but not 3757739 or 3757740 (Panel/Suburban). Roy
#16 |
Update: Installed these 55-59 grommets last night. Once you fold them over to squeeze them in the fender bracket hole, they move around a good bit. Probably could squeeze them into a smaller hole. Hope I'm done taking these fenders on and off.. lol
