#4426 | |
![]() ![]() Join Date: Jan 2005
Re: What did you do to your truck today.The 3rd chapter
#4427 |
#4428 |
Had 3 friends meet me at my place after work to pick up the truck box and set it back on the frame. I got the box bolted back down. I have new 2” drop springs installed in the rear. It looks better already. Looking forward to getting the front springs done and some 31” tires on. I think the truck will look sharp.
#4429 |
![]() Join Date: Jun 2022
got my heater control back together and back in, sits a little crooked, but I'll deal with that later. Did some CAD(cardboard aided design) work on the glove box, should start bending metal tomorrow for that
#4430 |
![]() Join Date: Sep 2016
Installed vintage air unit under the dash and duct hoses and a few more pieces of kilmat.
#4431 |
Deleted.
"If it ain't broken, fix it 'till it is!" Last edited by Extended Power; 12-10-2023 at 09:32 PM. Reason: Same post. Deleted. |
#4432 |
Applied my 0-8000 rpm stencile from PJMORELAND.
Scared I was gonna fog the lens with the spray cleaner I used, but it worked. Thanks Patrick. The tach went from busy and completely off, to clean and properly centered.
"If it ain't broken, fix it 'till it is!" |
#4433 |
OH! good to know! I plan to do the same, soon. Lucky for me, I already found out my front cab bolts are not spot-welded, and there's no rusted on nut/bolts as my truck was garaged for most of it's life. My bushings aren't bad, but thought it's a good time to redo.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
#4434 |
#4435 |
#4436 |
Played with paper dolls: First cardboard template for the glovebox interior(traced from the remains of the original) wasn't really working great for tracing out the sheet steel parts, so I started over with some skinnier stock.
Also working through a Fusion360 tutorial for bent sheetmetal parts so I'll be able to make a grown-up drawing. Last edited by Rust_never_sleeps; 12-13-2023 at 03:57 AM. |
#4437 |
![]() ![]() Join Date: Apr 2022
Got a decent clip of the new motor this morning. Finally got some dry (but cold) weather to get some more break in miles on the new combo
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
#4438 |
Odd double post, but truck ran great. Loving the 5 speed on the highway.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy Last edited by CAMAROBOY68SS; 12-16-2023 at 04:57 PM. Reason: double post |
#4439 |
![]() Join Date: Mar 2021
It sounds healthy and it looks great man, well done
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
#4440 |
Struck down, dead center, a jay-walking pedestrian in a red suit
(Holiday parade and lighting festival in the 'burbs jut outside Seattle)
#4441 | |
#4442 |
Started bending metal for glovebox. I've never bent metal before and it's going about as well as I should have expected
1970 C10 Custom longbed 350/350 |
#4443 |
Tore the front end apart. Rotors and calipers were new, everything else is in need of replacement. Made a list of parts to order. Cut the rivets off upper ball joints and got them out. Will need to get a tool for the lowers.
I have 1” drop springs, The original springs had 1” rubber isolators, so the front will sit 2” lower than before. Excited to get this back together and see how it looks. |
#4444 |
Just a GM L79 327/350hp cam.
#4445 |
....and for the other end of the todo list, windshield seal leaking prodigiously :-|
#4446 | |
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#4447 |
#4448 |
Wanting to fill up the gap between tires and fender. If there is too much gap after putting 31x10.50-15s on, I’ll go with a drop spindle.
#4449 |
oh yeah. This motor came with a wicked set of 186 factory 2.02 heads. They were really ported at some point on the intakes and the exhaust ports were slightly smoothed up. Stainless valves and screw in studs. Then the intake is a 69/70 Z28 over the counter piece (only difference was a little bowtie on the rear runner behind the carb.)
#4450 | |
