Old 12-11-2023, 11:28 AM   #76
loudchevy
loudchevy's Avatar
Re: Thoughts on Gen 5 Vintage Air Install
Great info in this tread. What are you guys doing with the kick panel/cowl vent doors? Just keeping them permanently closed?
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 12-11-2023, 11:46 AM   #77
pjmoreland
pjmoreland's Avatar
They are still usable. The passenger Vent door can't be opened all the way, but it can be opened enough to work.
pjmoreland is offline   Reply With Quote
Old 12-11-2023, 12:12 PM   #78
loudchevy
loudchevy's Avatar
My truck had factory AC, so the passenger kick vent and cowl vent had vacuum actuators on them. I read through the VA install and didn't see if and where they were reused/integrated into the new system. Only the drivers side kick vent had the manual rod to open/close it.
Scott
2003 Tahoe Stock
Old 12-11-2023, 12:39 PM   #79
pjmoreland
pjmoreland's Avatar
Maybe you could replace your passenger vent door with one from a non-A/C truck. Here are some photos
Old 12-11-2023, 12:58 PM   #80
loudchevy
loudchevy's Avatar
Thanks for the pics. I see why the vent can't be opened all the way, that is a tight fit! I think the doors are the same, I would just need the manual linkage.
Scott
2003 Tahoe Stock
