Junior Member
![]() Join Date: Oct 2022
Tremec T56 Magnum
Ive found a T56 magnum to buy across here in the UK for a reasonable price.
I'm wanting to change to manual from my TH350 mounted on a 305 on my C10 and it seems to be a good choice from the reading up I've done. I dont have much experience in transmission work so hoping you guys can give me any advice on it or questions I should be asking the seller about the T56 He also has a T10 very cheap but I cant find alot out about them Thanks as always |
Re: Tremec T56 Magnum
I have a T56 magnum in a car of mine, it's awesome. You'll need a different bellhousing set up, hydraulic throw out bearing/clutch master cylinder etc but I'm sure can't be too tricky to get it into the truck.
The magnum has two shifter locations, and a separate bellhousing making it a universal fit transmission versus the integral units found in production vehicles.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
#3 | |
There are quite a few versions of the original T56, the T56 Magnum, and the TR-6060. Be sure you are getting what you are paying for. |
#4 | |
The Older Generation
I don't know a lot about the T-56 but I'm just curious why you are saying he would need a hydraulic throw out bearing and master cylinder. Can't the trans be used with a stock Chevy manual bell housing and clutch setup? LockDoc
The T56 magnum needs an LS style bell housing. It can’t be used with a traditional Muncie style bell housing. I don’t think the transmission and clutch set up is compatible with manual linkage - but I could be wrong.
The t56 magnum is not a T56, the naming is confusing. It is a variant of the production TR6060 found in modern Camaros, challengers, etc. Just with a non integral bellhousing and two shifter locations. The TkX 5spd tremec came out with can be used with a Muncie style bellhousing which is why it’s been a good addition and fits a lot nicer than the giant t56 magnum. I really like the 6 spd though. I run 4.10’s and a shorter tire and still cruise 75 at 2200-ish rpm in 6th.
#6 | |
OK, thanks. I thought the Magnum might be the same as the tremec. LockDoc
Still made by tremec but doesn’t share any similarities with the T56 found in older GM cars. Kind of confusing.
#8 | |
![]() ![]() Join Date: Apr 2022
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
#9 | |
Thanks for the input. LockDoc
![]() Join Date: Feb 2022
It is likely Quick Time, now owned by Holley, will have whatever combo, engine to trans, mechanical or hydrolic, you desire. I put a Jerico dog box behind a LS2 15 yrs ago using 7 inch quarter master clutch and flywheel and hydrolic clutch. Quick Time had the housing that set the Jerico in perfect position. Oh and it all slid right into a BMW Mcoupe. As for the T56 magnum. Great street box. Ok track box if you slow your gear change just a tiny bit.
#11 | |
Active Member
![]() Join Date: Nov 2018
Make sure you check the part number tag on the transmission and compare it to Tremec's catalog. There are a lot of variations over the years and they won't all work. |
#12 | |
The 3rd gen Camaro's (82-92) had a T5 5 speed (except 82, last year of the 4 speed) They used a more typical bellhousing that had the same bolt pattern as a Muncie/Super T10. They had a oddball clutch setup where is was a mix of both mechanical and hydraulic. It was hydraulic on the pedal down to the bellhousing, but then there was a bracket cast onto the bellhousing that mounted a plunger that would then work a typical fork throwout bearing.
#13 | |
Active Member
You can use the LT(SBC) T56 with an LS, but you need to change the bellhousing and input shaft. Input shafts were longer on the LS transmissions if I remember right. I seem to recall a difference in the front plates as well but I can't remember if you needed to change them or not. |
#14 | |
#15 |
Maybe, but the 2 LT1 stick F bodies (both 97's) I have worked on were full hydraulic. They could have been converted as they had alot of stuff replaced over the years other than the motor. Only other early 4th gens I have had/worked on were Auto's.
#16 | |||
"I ain't nobody, dork."
Gary
