Old 12-22-2023, 09:49 PM   #26
Jim Boy
Re: Front coil spring question
novaX522
I think you have a point there about getting the frame at least checked. Now the problem is finding a place that knows what they are doing. With so many unibodies out there and truck owners that couldn't care less if something isn't right as long as it gets from A to B, qualified workers are becoming a rarity these days. It's hard to talk to a lamp post eh. On to the Todo list it goes and will be top of the list 2024. Have a good holiday stay safe.
Jim Boy is offline   Reply With Quote
Old 12-23-2023, 11:04 AM   #27
CC69Rat
CC69Rat's Avatar
Originally Posted by Jim Boy View Post
CC69 Rat-- I've been pulling my hair out over the slant in the truck when viewed from the rear. I have replaced almost everything front and back that could affect the tilt but to no avail. This is the first post that confirms that a tilt is there. My question is:: where did you read that GM built the trucks with this configuration built in to compensate for road crown. It's the little things that drive you nuts and makes you lose sleep. Have a good day and be good. Santa is almost packed.
If you research "Chevy Lean" on Google, probably on YouTube too. It is a known issue with the 63-87 C series, OBS, S10s, etc. Belltech makes a spacer to correct it.
The truck will sit lower on the drivers front, and higher on the passenger rear. If you put the spacer in the drivers front it will offset it.
I thought this might be the issue with the OP question, but he said his had the spacers in both sides. Someone probably added them at some point.. who knows.
Good luck with getting it worked out.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
