Old 12-29-2023, 05:10 PM   #1
Rust_never_sleeps
Rust_never_sleeps's Avatar
wiper blade refills
Didn't see a recent thread on this....
I didn't find replacement blades locally, only blade+bow types so I bought some material off the river, and it went on great.
There are numerous offerings in rubber or silicone. the dimensions are shown below(6mmx10mm equivalent)
They come molded together at the skinny edge, which seems to throw people, but they just pull apart
I kept the steel ribs and clip from the previous blade and just cut the rubber to fit and slid it in(with the clip sandwiched back in)
As always, it stopped raining when I bought fresh wipers, so can't give a road test report yet.
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 12-29-2023, 06:29 PM   #2
dmjlambert
dmjlambert's Avatar
Re: wiper blade refills
I am interested in this and have kept the old refills that need new rubber. Do you have any pictures or video for a how-to? And is the rubber you got from Amazon or eBay and can give a link?
Old 12-29-2023, 07:15 PM   #3
Husker
Husker's Avatar
Needing to know.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 12-29-2023, 07:22 PM   #4
Rust_never_sleeps
I bought these in 26" sections strictly because they were a next day item, but it'd be less wasteful to buy in 30" lengths or one long strip. Numerous sellers here with presumably the same product
https://www.amazon.com/dp/B0BQBMF3V7
I'll undo one and snap a few pix, but it's pretty simple.
These do come attached at the skinny edge like an I-beam, which seems to trip up some folks, but they pull apart easily.
Code:
            __
     ______|__]\____
Old 12-29-2023, 08:10 PM   #5
dmjlambert
dmjlambert's Avatar
I find it great that these use "natural native imported rubber flavor combined with teflon technology." Native and imported and flavored and teflon sprinkled in there somewhere, how can you go wrong?
Old 12-29-2023, 08:12 PM   #6
Rust_never_sleeps
here's the sequence:
It looks like I cut this with a seeing eye dog and a butter knife, but you want it to reach the end of this skinny area on both ends:
I measured this at 14-9/16"
Code:
            __
     ______|__]\____
Old 12-29-2023, 08:15 PM   #7
Rust_never_sleeps
My steel "rails" look like this, note the taper at the left edge of the larger rectangular gap:
Code:
            __
     ______|__]\____
Old 12-29-2023, 08:17 PM   #8
Rust_never_sleeps
Feeding from Right to Left here, I start the bottom groove onto the rails at that tapered spot:
Code:
            __
     ______|__]\____
Old 12-29-2023, 08:19 PM   #9
Rust_never_sleeps
Slide it all the way to the other end, and the right end should be easy to pop through the rectangular notch:
Code:
            __
     ______|__]\____
Old 12-29-2023, 08:26 PM   #10
Rust_never_sleeps
Slide the rubber back to the right so it looks something like the first picture above. Should have the smaller rectangular notch visible on both ends.
Next, stick the latch clip between wiper and steel rails and keep pushing until the barbs drop into that small notch:
(I have the barbs pointed down, but I can't think of a reason it wouldn't work the other way around)
Code:
            __
     ______|__]\____
Old 12-29-2023, 08:29 PM   #11
Rust_never_sleeps
To me, they taste more garden hose water on a hot day, and less like coolant hose, but my palate isn't what it once was ;-)
Code:
            __
     ______|__]\____
Old 12-29-2023, 08:31 PM   #12
dmjlambert
dmjlambert's Avatar
Fantastic how-to, thanks a bunch. I will try that.
Old 12-29-2023, 09:15 PM   #13
Jason Banks
Jason Banks's Avatar
If this doesn't get the pro tip of the day award, I can't imagine what would.
Jason Banks is offline   Reply With Quote
Old 12-29-2023, 09:19 PM   #14
Husker
Husker's Avatar
Thank you I will try them.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 12-29-2023, 09:22 PM   #15
Rust_never_sleeps
I fear that might give folks the mistaken idea that I know what I'm doing ;-)
Code:
            __
     ______|__]\____
Old 12-29-2023, 10:53 PM   #16
dmjlambert
dmjlambert's Avatar
It's called building a reputation :-)
Old 12-30-2023, 04:56 PM   #17
54blackhornet
54blackhornet's Avatar
After seeing this thread I went out to my shop and took this off the shelf. I bought four pairs years ago. Glad I stocked up on them.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-30-2023, 05:10 PM   #18
dmjlambert
dmjlambert's Avatar
Yes, I have some extras as well. I used to throw the used ones away. I'm keeping the old ones now as I take them off the truck, and will be doing this rebuild in batches.
Old 12-30-2023, 05:24 PM   #19
HO455
HO455's Avatar
Great thread! I guess I'll be searching the interweb tonight.
RIP Bob Parks.
Old 12-30-2023, 05:28 PM   #20
MySons68C20
MySons68C20's Avatar
Great stuff!!
MySons68C20 is offline   Reply With Quote
Old 01-06-2025, 12:48 PM   #21
Graham57a
Graham57a's Avatar
Great thread! Just ordered a set
Graham57a is offline   Reply With Quote
Old 01-06-2025, 03:29 PM   #22
MARKDTN
Our O'Rielly's stocks the refills but you have to ask for them, they are not out front with the others.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-06-2025, 04:34 PM   #23
Ironhorse
Ironhorse's Avatar
Would you post the part number you ask for at the counter? Our local O'Rielly's is a "year, make, model, engine, transmission" kinda store. Sure miss the locally owned Mom & Pop stores where simple, normal use and replace items were just a tell them what you want type situation.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 01-06-2025, 05:45 PM   #24
MARKDTN
Looks like the Anco refill was p/n 12-15. 33-150 Trico "Classic" is the whole blade in old style for a truck still available at Orielly's. Not seeing just a refill anymore. Sad. I actually bought there searching for a C3 Corvette a few years back. You can't use modern blades under the wiper door on a 68-72 Corvette. First set of refills I had for it I bought at Walmart for 99 cents for the pair I think.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 01-07-2025, 07:57 PM   #25
tinman_local2
Just bought a set of 33-150 Trico classics today at our local O'Reilly. Perfect fit and look like an original. Much easier than ordering online.
tinman_local2 is offline   Reply With Quote
