Old 01-08-2024, 04:30 PM   #1
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Steering Shaft upgrade XJ or Astro Van?
Im Rebuilding the front end on my C30 Im looking to replace the worn out rag joint and rubber isolater on the top as it worn out
I was looking into buying a XJ steering shaft but i came across this post thats seem that Astro Van shaft are about the same length and couplers too?
https://www.thirdgen.org/forums/engi...astro-van.html
Anyone know if an Astro shaft will work, they are commen in my part of the world weres the XJ is not, Shipping over seas are expensive so if i can get one local to me it I would save alot
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 01-09-2024, 12:32 PM   #2
rodstored-72
chevy truck fan
rodstored-72's Avatar
Re: Steering Shaft upgrade XJ or Astro Van?
GMTgmt, I did the XJ shaft conversion on my '86 (it is shown in my build thread on here) I am happy with the result, there is a thread on how to do the conversion on here and I THINK it discusses the astro shafts in there as well.. overall I think the swap is worth it.
rodstored-72 is offline   Reply With Quote
Old 01-10-2024, 10:13 AM   #3
SCOTI
SCOTI's Avatar
From what I understand in the g-body/Malibu world the Astro shafts require re-clocking one end to have the necessary alignment (the g-body & C10 stuff is similar).
The re-clocking requires cutting & re-welding of one end which is not required for the XJ swap.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-10-2024, 02:12 PM   #4
GmtGmt
GmtGmt's Avatar
Thanks, I got a shaft from a astro on the way, just and sleve it is not a problem so i will se if it can be made to work
Thomas
Old 01-10-2024, 09:30 PM   #5
LT7A
If you can, come back and let us know how it goes. It would be interesting to find out if that's an easily workable option.
Old 01-15-2024, 09:19 AM   #6
Axle
Axle's Avatar
I used a jeep shaft. One tip I would give is make sure you heat the plastic that locks in the slip shaft enough that the shaft freely moves in and out. Theres enough flex between the cab and steering box to cause popping if you leave it as a tight fit to adjust the length (even with liberal lube on it). In the end, I ended up knocking all the plastic out (there isn't much of a second chance). Definately an improvement over the rag joint, and even with no plastic to take up the "slop" in the slip shaft it is still miles ahead of a rag joint.
Axle is offline   Reply With Quote
